Looking for the accessory wire from ignition? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 09-14-2009, 05:34 PM Thread Starter
ASTRO's Avatar
Does anyone know which wire/color of the accessory wire from the ignition switch? I have a relay I need to power off of the accessory side of the ignition , it`s to my new dvd stereo? Thanks for any help!!
MY 2002 f250 4x4 larait crew cab short bed. 12.5" Icon lift w/ OneUpOffroad 5" traction bar block system. Mickey thompso 38X15.50R18 tires on Weld Dune 8 18x10 wheels. Custom pearl silver &purple flame paint, MBRP 4" T-304 SS cool dual exhaust w/ custom made T-304SS flame tips, AFE stage 2intake. Way More!
ASTRO is offline
post #2 of 6 (permalink) Old 09-14-2009, 09:13 PM
recon250's Avatar
Re: Looking for the accessory wire from ignition?
theres a yellow and red one under the dash going into a plug thats not plugged into anything that i get the power from for my guages,
02 f-250 xlt with leather, BTS trans. dp-tunes, afe. 40" bfg km2 on some 20's. and a bunch of other stuff that doesent make it any faster.
recon250 is offline
post #3 of 6 (permalink) Old 09-14-2009, 10:07 PM Thread Starter
ASTRO's Avatar
I`m needing the accessory wire the is powered when you turn the key backwards. I have a kenwood dvd headunit I`m hooking up and I bought a relay off ebay the you wire into the accessory wire not the ignition or battery to fol the dvd into playing when the truck is moving.
ASTRO is offline
post #4 of 6 (permalink) Old 09-14-2009, 10:50 PM
6.0beau
6.0beau's Avatar
find the wiring harness going into the steering column and use a test light or a voltmeter and test the wires. i believe it is yellow.
2006 f250 XL Single Cab 2wd-- BLOWN UP AND GONE
SCT Livewire w/ Matt"s Tunes
4 inch straight pipe
AFE stage 2 intake
Zoodad Mod
2001 Ford Excursion Limited 4x4
4 inch Magnaflow
SCT SF3
1994 F350 CCLB 4x4--SOLD
TS 6 Pos chip
S&B intake
6" Superlift
37x12.50 BFG Mud Terrains
2012 F-350 FX4 XL
Stock
Free
6.0beau is offline
post #5 of 6 (permalink) Old 09-14-2009, 10:53 PM Thread Starter
ASTRO's Avatar
THANKS!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!
ASTRO is offline
post #6 of 6 (permalink) Old 09-15-2009, 01:11 AM
PSN's resident Blue Man
Firedogbme's Avatar
For the accessory position, you've got three choices at the ignition switch:
Grey/yellow stripe,
Red/Black stripe,
Blue/Lt. Green stripe.
Any one of those will work for you. I'm going off your sig that you've got a 2002, right? The wire location and colors change from time to time, let me know if you have a different model year.
Bruce
Early '99, 4X4, CC, SB, Fire Engine Red
-JNB Fuel System, Sinister Overboost, C2 gauges, AFE Stage II w/ "JAT99" Intake Pipe, CCV Bypass, 3.5 dp to 4" exhaust.
-BTS Trans and Converter
-WOP QSSB Turbo
-Terminator HPOS
-DP F5 w/ 60Tow, 80Econ, 120Race, 140Extreme, High Idle, Upgraded to PMT PCM - Live tuned
Firedogbme is offline
