clicking blinker relay - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 09-01-2009, 02:42 AM Thread Starter
my relay for the blinker and brake lights clicks when your not turning or using the brakes. the clicking is spuratic and it can be just sitting in park and does it. you dont have to be turning the steering wheel also to hear it click. i changed the relay but it didn't help. any ideas?
wiscfordguy is offline
post #2 of 6 (permalink) Old 09-01-2009, 04:22 AM
Starting Over
kainers's Avatar
Re: clicking blinker relay
bad/loose bulb?
My 02 did this when I would loose a bulb.You could also have a short somewhere.Just throwing out suggestions.
What year is your truck
kainers is offline
post #3 of 6 (permalink) Old 09-01-2009, 12:01 PM Thread Starter
03' sdcc . when your truck did the clicking where you using the blinker or anythink cuz mine does it all the time even when im not using anything and its just sitting and running.
post #4 of 6 (permalink) Old 09-01-2009, 08:13 PM
Starting Over
kainers's Avatar
Yeh only when I used the blinker.I would start checking for chafe or rats nest what have you.Electrical problems are a PITA.Wife's old 99 dually had some serious electrical issues.Got rid of that POS it was so problematic.
kainers is offline
post #5 of 6 (permalink) Old 09-12-2009, 01:05 AM
<---- my shop
vader's fury's Avatar
i had the exact same problem on my truck and after 2 weeks of looking i found the problem. There is a relay under the dash right behind the plug for where you would hook up a trailer brake controller that has 2 relays in it. I dont remember which one of the 2 it was but that was the problem. That relay works with the brake lights and turn signals. let me know if you need any more info.
vader's fury is offline
post #6 of 6 (permalink) Old 09-13-2009, 07:18 PM
your just low on blinker fluid
catadj is offline
