Adding Cruise control? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 09-01-2009, 02:37 AM Thread Starter
Send a message via AIM to JohnT
I have been kicking around the idea of buying another super duty, but I am looking for the cheapest one possible and none of them have cruise control.
Has anyone added cruise control to a truck that did not have cruise control in it? I have the steering column with cruise control wheel, just wondering if there was a way to wire it up?
TIA
99 PSD 4x4 CCLB
05 PSD 4x2 RCLB
JohnT is offline
post #2 of 7 (permalink) Old 09-02-2009, 04:14 PM
Jeremy's Avatar
Re: Adding Cruise control?
Piece of cake. The only thing your missing if its a auto tranny is the brake master cyl, you need one with the sensor on the end. Your truck will be wired for it, the harness end is tied up on the fender.
You need:
Cruise wheel
Clock spring
master cyl with the sensor on the end.
the rest is plug n play
16 6.7 F-350 XLT SC 4x4 auto
06 6.0 F-250 XLT SC 4x4 auto
05 6.0 Excursion EB 4x4 auto
00 7.3 F-350 Lariat CC 4x4 12 speed
95 7.3 F-Superduty XL PSD Auto Mechanics Truck
94 7.3 F-Superduty XL PSD 5 Speed 12ft Flatbed
93 7.3 F-Superduty XL IDI 5 Speed 12ft Dump bed
Jeremy is offline
post #3 of 7 (permalink) Old 09-02-2009, 11:46 PM Thread Starter
Thanks Jeremy! I was hoping the answer would be something along those lines! Sounds like I have everything except the master cylinder with sensor, which don't seem to hard to track one down.
So the wires are also inside the truck cab also to hook up to the steering wheel? Im guessing you have done this before?
99 PSD 4x4 CCLB
05 PSD 4x2 RCLB
JohnT is offline
post #4 of 7 (permalink) Old 09-03-2009, 03:15 PM
Jeremy's Avatar
Yea the cruise control clock spring plugs into the same place the non-cruise clock spring, and all the wires are there.
You can bypass the plug on the end of the master cyl, its a backup cruise control cancel switch. Cut the head off the harness, and hook the two wires together. The cruise will still turn off when you touch the brake pedal, provided the main brake switch on the pedal does'nt fail.
Jeremy is offline
post #5 of 7 (permalink) Old 09-03-2009, 05:55 PM
Won't you need the steering wheel with the cruise control buttons? Or was that what you said you have in your first post?
1999 Ford F250 with 2004 Cummins backed by a BTS transmission. FASS 150/150, ARP head studs, ATS exhaust manifold, Hellman Fuel Sump, Hellman intake manifold, Hellman fuel bowl delete, Smarty Revo SW#9, Hydraulic assist, Custom traction bars
Pictures:
Aggie007 is offline
post #6 of 7 (permalink) Old 09-03-2009, 06:40 PM Thread Starter
Thats what I meant in my first post, is that I have the steering wheel with cruise control buttons sitting in my garage, with the clock spring.
Thanks Jerermy again for your help! I was beginning to think no one knew the answer to this lol.
99 PSD 4x4 CCLB
05 PSD 4x2 RCLB
JohnT is offline
post #7 of 7 (permalink) Old 09-03-2009, 08:32 PM
Jeremy's Avatar
John,
Make sure your clock spring is the same, by that I mean the connector end of the clockspring that under the column with the bright yellow loom. The grey harness end changed in 2002 I believe.
Jeremy is offline
