Electrical question - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 3 (permalink) Old 08-27-2009, 07:58 PM Thread Starter
Electrical question
Can someone tell me what the 3 relays are for directly to the left of the fuse panel under the dash? I seemed to have misplaced my owners manual. In another thread I described a problem I was having with my dash lights flickering uncontrolably every now and then. And it was some how effecting my transmission causing it to downshift every time they would do it. I discovered yesterday that by wiggling any of those 3 relays I can duplicate my problem. In my experience when a relay goes bad they just die and quit working. Does it sound like some bad relays or what?
jgos929 is offline
post #2 of 3 (permalink) Old 08-28-2009, 02:51 AM Thread Starter
Re: Electrical question
Come on guys Nobody ?????
jgos929 is offline
post #3 of 3 (permalink) Old 08-28-2009, 11:14 PM
2000 F350 SuperDuty 4x4
Calico5's Avatar
Try this:
Click here: http://www.motorcraftservice.com
Then select "Owner Guides" on the left column, then select your year and model from the drop-down lists.
Wait for it to download completely. You'll then be able to view your owner guide. You can also save it to your computer by clicking the "diskette" looking icon near the upper-left of the PDF, then select a location, then click "save".
Hope that helps...
Al in SoCal
AFE Intake; Garrett 38R; Turbine Jacket; Banks IC, BanksBrake
Melling LPOP, External Oil Cooler & Filter System
Stealth 4-line Twin HPOP,
Swamps 160/30's, HVHF IDM; DP-Tuner F5
Full R-R Fuel System, Pre-& Post-pump filtration
Mishimoto Rad & Tank; 4" Exhaust, Twin Aussie Stacks
SouthBend D-D Clutch; ZF 6-spd, GearVendors O/U Drive
Calico5 is offline
