Wiring Gurus i want to know how to - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 9 (permalink) Old 07-27-2009, 02:26 AM Thread Starter
RSP
livin the dream
RSP's Avatar
make the led on a switch come on if I am using the switch for grounding instead of + Supply
Its a on off switch, has built in LED and has three blades on the back, 1 for ground (has little wire off of it to I assume the LED) 1 for the Acc and one for Positive. any ideas how to do it?
09 F-350 CC DRW 5" Flo-pro,SCT w/Edge CTS, S&B Intake.
97 F350 4X4 CR, Destroked Plates, BTS 4R100 w/pcs, DDP 38 lpm Nozzles, Dual CP3s, Custom age Head Studs, Fire Rings, II silver62 over S480.
79 F350 4X4 SC Lariat CTD, BTS 4R100, DDP 78lpm, Pias/480 combo. Columbus 900cc 13mm race pump
RSP is offline
post #2 of 9 (permalink) Old 07-27-2009, 04:23 AM
POWERSTROKER's Avatar
Re: Wiring Gurus i want to know how to
Use the positive and ground spades.
One wire coming into the positive blade, and one wire leaving the ground blade (to ground). The ACC blade will not be used.
Hooling it up like this will complete the circuit, and should make the LED illuminate when turned on.
Early 1999 (4/98) 7.3, Automatic, f-250 superduty, 4x4, crewcab, shortbed.
CCV Mod
knn intake
banks exhaust
banks power elbo
banks turbo housing
big head waste gate-disconnected
Tuning by
4 gauge pod with DiPricol pyro, boost, trans temp, HPOP
POWERSTROKER is offline
post #3 of 9 (permalink) Old 07-27-2009, 04:37 AM Thread Starter
RSP
livin the dream
RSP's Avatar
ok but where is the power coming from to make the LED work? Im lost.
RSP is offline
post #4 of 9 (permalink) Old 07-27-2009, 04:44 AM
it should have wiring internally to make the led light
halerazor is offline
post #5 of 9 (permalink) Old 07-27-2009, 05:50 AM
Forged rods R 4 SISSIES!
PowerHungry's Avatar
Do you have the diagram (or part number) for the switch? Most of them are designed to be positive switched (and 12 volts at that) but it may be possible to have it light negative switched.
Your best bet...
Purchase an additional relay, (like this one -> http://www.parts-express.com/pe/show...number=330-073) and wire the switch to be a 12V output instead of a ground. Use the 12V output to energize the relay and use the closed contacts of the relay to pull your line to ground. This is probably the best way to get the LED function you need.
Bill Cohron - (678) 890-1110
- The Original in Custom Ford PSD & Gas Tuning since 1997
FOREVER
2001 7.3L - Stage 1's and a Tymar - 399 HP
2004 6.0L - 440 HP #2 Only/482 HP on Boost Juice - 12.961 @ 102.6 MPH
PowerHungry is offline
post #6 of 9 (permalink) Old 07-27-2009, 12:51 PM
The Fireman
big_stroker's Avatar
If its the kind of switch I think it is you can just wire it backward. Hot where the ground is and ground where the hot is.
big_stroker is offline
post #7 of 9 (permalink) Old 07-27-2009, 01:11 PM Thread Starter
RSP
livin the dream
RSP's Avatar
I tried that and it didnt light up, I think what Bill said will work though, I was just trying to stay away from so many wires.
RSP is offline
post #8 of 9 (permalink) Old 07-27-2009, 02:28 PM
we do this at work all the time i work at Honda so all of our plc's are NPN and when we have a PNP component we use a relay to make it work. You shouldn't have to do this for just a simple toggle switch. What are you trying to turn on with the switch? If what you are trying to activate with the switch works properly and the led just doesn't light then the LED may be shot.
post #9 of 9 (permalink) Old 07-27-2009, 10:04 PM Thread Starter
RSP
livin the dream
RSP's Avatar
I need the switch to complete a ground circuit, No juice just ground, I also wanted the LED to light up when the switch is activated. I tried it like Bill suggested and it works so Im gonna go that route.
RSP is offline
