Headlight Trouble - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 07-22-2009, 06:29 PM Thread Starter
01platinum's Avatar
Headlight Trouble
I just did the 05 conversion on my truck and last night when I got in it and turned the headlights on I noticed the beam light was on in the dashboard. So I pulled the signal switch back thinking I pushed if forward. Nothing happened no light change nothing. So I turned the high beams on and the lights went out all that was on was my parking lights. Now when I turn my headlights on it is just normal power they are not on bright even though the light on the dash is on. What could this be? Thanks.
Real Diesels Have Stacks
New Tunes by Matt @ Gear Head - Auto Meter Gauges from Nate @ PTP
Air Dog II Fuel Pump
First RR Fuel System built by hand @ Murff Racing
More to come soon..........
01platinum is offline
post #2 of 6 (permalink) Old 07-22-2009, 07:15 PM
diesellee's Avatar
Re: Headlight Trouble
If you have the aftermanrket harness you need to check your grounds. Been there done that.
2000 F250 4x4. Full motor build from SWAMPS.. Bcode injectors, gt42 turbo and all the other crap that goes with it.
diesellee is offline
post #3 of 6 (permalink) Old 07-22-2009, 11:17 PM
mike61's Avatar
heck the adapter harness, when i got mine the wire for highbeam had pushed out of the connector
mike61 is offline
post #4 of 6 (permalink) Old 07-22-2009, 11:23 PM
GoNavy!
DcMoore999's Avatar
I'm having the same problem but I think mine might be somewhere else.. Your might just be a bad bulb or a ground. I made my own ground on mine a couple years ago but it still didn't help the problem.
2000 F-250, RCLB, Auto!!
DcMoore999 is offline
post #5 of 6 (permalink) Old 07-23-2009, 02:44 AM Thread Starter
01platinum's Avatar
Ok update. Driving home tonight and the passenger side light goes out. A little while later the driverside starts to get dim but is hanging in there. I get home back in the drive way turn the truck off but leave the lights on. Open the hood and all I smell is burnt plastic I pull the connectors apart on the passenger side and make sure all it tight and pushed into place. Move to the driver side and the wires are so hot I can barley touch them to get them apart. When I grabed the harness the light went out. So I got the flash light and looked at the wire harness and you can see the wires exposed now.
This really sucks only a month and having these kinds of problems already. Guess I'll have to get a new set of wire harness or just bite the bullet and buy HID's.
post #6 of 6 (permalink) Old 07-23-2009, 02:47 AM
GoNavy!
DcMoore999's Avatar
Sorry to hear about that man, that sounds kind of like me.. Keep us updated when you find the cause.
