Dumb ? about hood light - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 12 (permalink) Old 07-11-2009, 05:39 AM Thread Starter
What makes the hood light come on? Where is the switch?
My bulb burned out, so I replaced the hood light w an LED light.
I noticed tonight what the light did not turn off when I shut the hood.
I checked that it was latched correctly. Shut it again, but the light still stayed on. I had to unplug the connector.
Any ideas?
Sean
99 F350 CCLB
skav is offline
post #2 of 12 (permalink) Old 07-11-2009, 02:00 PM
SD01WD's Avatar
Re: Dumb ? about hood light
Must be a "murcury" switch, the liquid, when lifted, makes the connection
and when the hood is down it "breaks" the circut. If I can get to it, I'll
see what I find on my truck.
2001 SD 2 wheel drive
DP tuned by Scott @ TNT of CC
ITP Regulated Return/ in tank & prepump mods: When Only the BEST will do!
Tank has been harpooned
Gages: Boost and Pressure
on the post & 4" S/S turbo Back by Aljay.
Rancho's all around
SD01WD is offline
post #3 of 12 (permalink) Old 07-11-2009, 03:12 PM Thread Starter
I guess that would make sense, but it seems like there should be a better way.
I wonder how often the light comes on during the day.
99 F350 CCLB
skav is offline
post #4 of 12 (permalink) Old 07-11-2009, 05:28 PM
chris 0.'s Avatar
i didnt know we had a light...
i better get that fixed....
chris 0. is offline
post #5 of 12 (permalink) Old 07-11-2009, 08:06 PM
PSN Mega Miler
crowz's Avatar
No light on mine. Guess I need to look to see if its a bulb missing or if its even there on mine.
2002 F250 SuperDuty Lariat PSD 7.3 Crew Cab 4x4 302,000+ miles.
, Valvoline Extreme Blue 5w40 Synthetic,
, Clifford Matrix 50.5x Alarm
, P3 Brake Controller, Swamps Injectors, PHP Tunes
crowz is offline
post #6 of 12 (permalink) Old 07-11-2009, 09:10 PM Thread Starter
Are you guys saying that you don't have a light under the hood, or are you saying that you never open the hood?
99 F350 CCLB
skav is offline
post #7 of 12 (permalink) Old 07-11-2009, 09:17 PM
All done now
Arisley's Avatar
Mine broke. I want a hood light out of an old F150, the one that actually puts out some light and will pull out of the bracket and can move to anywhere on the truck to use as a drop light.
Arisley is offline
post #8 of 12 (permalink) Old 07-11-2009, 09:33 PM
06powerstroke's Avatar
The switch may be fine, LED's just do strange things sometimes. I replaced my dome lights in my old truck with LED's, and they wouldn't turn fully off. Try swapping a regular bulb in. It only takes 1.5v to run an LED, so a little power may still run through a merc switch, causing it to stay on.
2006 F250 CC LB FX4 Lariat
ARP studs, SCT X3 IDP & Gearhead tuned, S&B CAI, straight pipe, FASS 150/180, FCDP solid uppipe, Dieselsite coolant filter
2.5" BTS leveling kit, 35" Xtreme A/T's on XD Hoss 18's, N-Fab prerunner bar w/ 3 9" Hellas
Pioneer double din, JL components, 3 10" Pioneer subs
06powerstroke is offline
post #9 of 12 (permalink) Old 07-11-2009, 11:11 PM Thread Starter
I ended up putting a spring switch under the hood. Same thing you use for an alarm. The problem is fixed.
99 F350 CCLB
skav is offline
post #10 of 12 (permalink) Old 07-12-2009, 01:23 AM
PSN Mega Miler
crowz's Avatar
Im saying my truck doesnt have a light or the bulbs blown. Nothings ever lit up when I opened the hood.
crowz is offline
