05 headlights and grill on an 03? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 07-10-2009, 06:17 PM Thread Starter
independentreb12's Avatar
Do they bolt right up or what are the modifications that need to be done?
2008 ccsb 4x4
a few things done
independentreb12 is offline
post #2 of 6 (permalink) Old 07-10-2009, 06:19 PM
06powerstroke's Avatar
Re: 05 headlights and grill on an 03?
I believe the grille will not fit with the bumper. The 05 grille is a little bigger. I also think you need to cut the old headlight adjuster out for the 05^ headlights to fit. Someone who has done this will be sure to show you the right path...
2006 F250 CC LB FX4 Lariat
ARP studs, SCT X3 IDP & Gearhead tuned, S&B CAI, straight pipe, FASS 150/180, FCDP solid uppipe, Dieselsite coolant filter
2.5" BTS leveling kit, 35" Xtreme A/T's on XD Hoss 18's, N-Fab prerunner bar w/ 3 9" Hellas
Pioneer double din, JL components, 3 10" Pioneer subs
06powerstroke is offline
post #3 of 6 (permalink) Old 07-10-2009, 06:25 PM
do a search. there are plenty write-ups.
PMRCM#1
slowleak is offline
post #4 of 6 (permalink) Old 07-10-2009, 07:15 PM
6.0 money pit
smokinstroker's Avatar
google and using search on here are your friends
smokinstroker is offline
post #5 of 6 (permalink) Old 07-10-2009, 08:25 PM
JDG's #1 Fan
99F250Smitty's Avatar
Send a message via AIM to 99F250Smitty
Good write up on the headlights:
pictures/ step by step headlight conv. - Powerstroke Nation
If you plan to keep your stock bumper then you will need to trim the grill:
An 05 bumper will bolt right up to your truck but you will need the correct brackets.
Brian
_____________________________________________
99.5 F250 Extended Cab Short box. 4x4.
99F250Smitty is offline
post #6 of 6 (permalink) Old 07-10-2009, 09:02 PM
you dont NEED brackets, it will still work, but yes, you will have to get different ones if you choose to
PMRCM#1
slowleak is offline
