electric window problems - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 2 (permalink) Old 07-09-2009, 09:48 PM Thread Starter
peterbilt'in
Rob02F350's Avatar
hey
well i have a problem with my window... it wont go down... if it does go down it stays down till i try and pull it back up...
just replaced the window lift motor... wiring fine going to it... just seems like the tracks bound up or something...
does anyone know how to dissaemble the window lifting mechanism??
thanks
-Rob
2002 F350 extended cab XLT, 4x4 auto,194K mi @ 10/25/13, ELF7405, DP F5, ultra light gauges, all kinds of "improvements" Yukon Grizzly locker 6K helper springs, x code fronts. 2 Y2K jetta Tdi. RC2 tuned
Rob02F350 is offline
post #2 of 2 (permalink) Old 07-12-2009, 11:32 PM Thread Starter
peterbilt'in
Rob02F350's Avatar
Re: electric window problems
I Found the fix!!!!!!!
i posted it under the 7.3 tech... for some odd reason. ha ha
check it out if you have the problem.. i fixed mine. and to bad i waisted the 85$ for a window motor
