08 Recon Mirror Lenses - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 06-28-2009, 06:38 PM Thread Starter
Adrenalin Junkie
I don't wanna break any plastic. Anyone got any handy instructions to install the Recon mirror lenses on my '08?
PSD Trav is offline
post #2 of 5 (permalink) Old 06-28-2009, 07:53 PM
Re: 08 Recon Mirror Lenses
tilt mirror glass all the way in, look inside between glass and plastic and you will see a release tab..
RIP ~~06 F350 Lariat,6.0,4X4,CC, Icon coilovers,Rize 4 link,afe pg7,fs2500 bypass,diesellite coolant bypass,4 phantom II gauges,1 spa-tech dual gauge oil & water,magnaflow tb exh,accufab elbow,amp power steps,ravelco,optima yellows,08 mirrors etc etc..
az350 is offline
post #3 of 5 (permalink) Old 06-28-2009, 09:36 PM
2000Censtroker's Avatar
Not tryin to derail this, but is above the same way the lenses on the 03-07 mirrors come off? If not can someone tell me how?
2000 F-350 Centurion Ed.CC LB, 6 in. Procomp lift, 37 in. Super Swamper Iroks, Weld F1 Commandos, Gt 38R, Dp Tuner F-5, Gauges, Afe PG7 filter, Diesel site boots, ATS triple disc converter, 7in. mitre cut stacks
2000Censtroker is offline
post #4 of 5 (permalink) Old 06-29-2009, 02:36 PM Thread Starter
Adrenalin Junkie
The older ones are not as easy. Check Recon's website and it will give you instructions for those ones.
I am taking mine back. Recon needs better quality control.
PSD Trav is offline
post #5 of 5 (permalink) Old 06-29-2009, 10:04 PM
what was the problem, mine did not fit as well as the stockers, they did not snap in very tight !
az350 is offline
