Is this a good single battery option? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 12 (permalink) Old 06-18-2009, 02:22 PM Thread Starter
I am thinking about moving my batteries to the frame. I am trying to find a single sealed battery that will do the work of the two batteries I now have.
I plan to build a tray and mount the battery/ batteries on the outside of the pass. frame rail.
Here are the batteries that I now have.
Odyssey PC1750T
These work great, but I am thinking about this as a single battery replacement.
PC1800 Odyssey Battery
Anybody have any ideas or recommendations? The CCA and everything else is pretty close between the two batteries.
99 F350 CCLB
skav is offline
post #2 of 12 (permalink) Old 06-18-2009, 02:31 PM
Caption This
444-4D's Avatar
Re: Is this a good single battery option?
Your OEbatteries had 1500 CCA's.
The batteries you are now using have 1860 CCA's.
That single battery has 1300 CCA's.
If only those who knew what they were talking about replied, this thread would still be on page one.
2000 F-250 CC 4x4 PSD Auto
444-4D is offline
post #3 of 12 (permalink) Old 06-18-2009, 03:01 PM Thread Starter
I read the specs a bit more carefully after posting.
DO you know of any single that can compare?
99 F350 CCLB
skav is offline
post #4 of 12 (permalink) Old 06-18-2009, 04:57 PM
Kinetik High Current Power Cells
3 or 4 options on there
sirnunya is offline
post #5 of 12 (permalink) Old 06-18-2009, 05:49 PM
Lovin Life...
02BigD's Avatar
Are those able to be mounted at different angles, or only straight up and down?
02-350. CCSB - Drivetrain by Stauffer, fuel by Swamps, air by Barder, tunes by Gearhead.
04-250. ECSB - In the shop...7.3 swap.
02BigD is offline
post #6 of 12 (permalink) Old 06-18-2009, 10:46 PM
Caption This
444-4D's Avatar
What are the specs on those 3 or 4 options?
444-4D is offline
post #7 of 12 (permalink) Old 06-18-2009, 10:48 PM
Caption This
444-4D's Avatar
Not that would be suitable for frame mounting or that would be smaller than the two you now have.
444-4D is offline
post #8 of 12 (permalink) Old 06-18-2009, 10:50 PM
7.3 PSD Mythology Expert
Powerstroke Racer's Avatar
My Bronco has been on 1 Optima red top since it's inception as the SD Bronco.
David Lott
Experience is what you get when you don't get what you want!!!
No purpose no happiness, know purpose know happiness ---> Happiness is a direction not a destination.
Powerstroke Racer is offline
post #9 of 12 (permalink) Old 06-20-2009, 04:04 AM
Pulling sled for hire
ParkerFly's Avatar
Odyssey PC1750T
According to the specs in the link he provided, the batteries he has now have 930 CCA's. I'm not sure where you're getting your numbers, but it's rare to see and OE or even many aftermarket batteries with more than 1000 CCA's.
Justin
Justin
#62
'97 F-250 - 255k
463 hp - 7-9-09
BDP/Casserly Stage 2's, Mod H2E, Stealth Stage 2, BDP fuel system, Comp 910s, 7.3 ic, live tuned by Jonathan @ BDP.
ParkerFly is offline
post #10 of 12 (permalink) Old 06-20-2009, 01:53 PM
NEVRNF's Avatar
I have run 1 of the Optima Commercial yellow top's. They are rated @ 1125 ca and 900 cca. They also can be mounted any direction. I just finished a battery tray to hold 2 of these on the drivers side of my Ex with the CR.
Optima group 31
Tony
02 Excursion CR conversion with a few go fast parts
The truck
should have built
FOR SALE
NEVRNF is offline
