05-07 gauge pods - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 17 (permalink) Old 06-10-2009, 05:20 PM Thread Starter
06powerstroke's Avatar
05-07 gauge pods
I currently have 5 gauges for my 06 and about to be 6. All I have for a pod is a 4 pillar pod. I was wanting to put the other 2 on the dash but....I can't find anything but a pillar pod for 05's and up. I have found dash pods, but they say 99-04. What are you guys using?
2006 F250 CC LB FX4 Lariat
ARP studs, SCT X3 IDP & Gearhead tuned, S&B CAI, straight pipe, FASS 150/180, FCDP solid uppipe, Dieselsite coolant filter
2.5" BTS leveling kit, 35" Xtreme A/T's on XD Hoss 18's, N-Fab prerunner bar w/ 3 9" Hellas
Pioneer double din, JL components, 3 10" Pioneer subs
06powerstroke is offline
post #2 of 17 (permalink) Old 06-10-2009, 05:51 PM
6Leaker
jdc753's Avatar
Send a message via AIM to jdc753
Re: 05-07 gauge pods
you can do the over the mirror pod (up to 4 gauges there) After that I think you would have to get creative making a steering column pod, or lower dash pod work on your truck or coming up with something entirely custom.
2005 F350 Crew Cab Long bed
6.0L / Auto 4x4
SCT X3 5" Magnaflow
4" RCD lift, a bunch of stereo gear and a computer
jdc753 is offline
post #3 of 17 (permalink) Old 06-10-2009, 06:02 PM Thread Starter
Can't do a overhead. I have a sunroof The switch and 2 lights are above the mirror already...
post #4 of 17 (permalink) Old 06-10-2009, 06:03 PM
f250ford's Avatar
yep I don't have any gauges on the pillar all are above the mirror....
f250ford is offline
post #5 of 17 (permalink) Old 06-10-2009, 07:05 PM
f250ford's Avatar
f250ford is offline
post #6 of 17 (permalink) Old 06-10-2009, 07:21 PM
GoNavy!
DcMoore999's Avatar
Take styrofoam block and some fiberglass and get to molding
2000 F-250, RCLB, Auto!!
DcMoore999 is offline
post #7 of 17 (permalink) Old 06-10-2009, 07:25 PM
Stroker67's Avatar
put three on your driver side pillar and three on your passenger side pillar, just a thought
Stroker67 is offline
post #8 of 17 (permalink) Old 06-10-2009, 07:53 PM
Layson's Avatar
You can just cut some holes in your dash right below the instrument cluster. I think CSIPSD has some pics of those... (2) gauges would fit real nice in there.
Layson is offline
post #9 of 17 (permalink) Old 06-10-2009, 08:03 PM
6Leaker
jdc753's Avatar
I think it all depends on what options you have in the truck and such. Mine these spots are both taken up, on the left is the switch for the adjustable pedals (that I never use) and on the right is the "command center" switches to check trip, mileage, hours and other stuff just above the odometer.
If you have a manual t-case and no power sliding rear window you could put a gauge in that spot on the dash, and pull out the 12V "power point" on the passenger side and put another gauge there.
F-650 lower dash panel would open up some room for some more gauges on the lower panel as well, or change over the 05-07 lower panel to an 99-04 lower panel and add the lower dash gauge pod.
6.0L / Auto 4x4
SCT X3 5" Magnaflow
jdc753 is offline
post #10 of 17 (permalink) Old 06-10-2009, 08:25 PM
<<< THE GAUGE WHORE...
CSIPSD's Avatar
Here are some pictures... My wife has an overhead pod in her excursion with the overhead display. It fits fine. Wish I had a picture of it, but there gone for some reason.
Joe
CSIPSD is offline
