Warning to VHT Nite Shades Users! - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 9 (permalink) Old 01-02-2014, 06:36 PM Thread Starter
Pissed in your Cheerios..
Diesel dumper's Avatar
Alright so about 6 months ago I used VHT Nite Shades spray tint on the headlights of my SD.
Well the shading got old and I wanted to upgrade and try some things with it, I expected to removal to be tough but not as tough as it was...
I spent literally 2 hours using NEK and a razor to get this stuff off and it barely put a dent in it and also ruined my headlights.... Wonderful...now I have to pay for some new headlights which I didn't need to do but now I have to... When I contacted VHT they were very helpful, I do give them that but I warn anyone planning to use VHT on their vehicle be careful....go easy because it sucks to take it off.
2002 F250 Ext XLT 7.3L, 140hp Phoenix chip, 2.5" Lift, Bushwhacker fender flares, Glow shift quad gauge pillar, EGT, Trans, Fuel Pressure, Boost, Spectre air intake, 6 inch angle cut stack, CFM Manifold, Riff Raff Intercooler Boot kit.
Originally Posted by southbend_powerstroke View Post
well around seattle washington my truck seems to stick out with all these hippies lol.
Diesel dumper is offline
post #2 of 9 (permalink) Old 01-03-2014, 10:25 PM
<<< THE GAUGE WHORE...
CSIPSD's Avatar
Re: Warning to VHT Nite Shades Users!
Wet sand would work just fine...
Its a paint, I hope it sticks good!
Joe
CSIPSD is offline
post #3 of 9 (permalink) Old 01-03-2014, 10:36 PM
dsberman94's Avatar
for anyone else who wants to stay away from VHT nightshade for this reason plastidip tint is a spray on application product that peels of just like all other plastidip when you want it to come off. or depending on where the item is and the curvature of the surface you could just go down to your local tint shop and ask for some pieces to do the job.
02
F250 7.3 Crew Cab Short Bed Lariat
4"dp 5 inch pipes to dual 8 inch stacks (summer)
4" turbo back dual axle dumps (winter)
PHP Hydra (loaded)
Edge insight CTS monitor w/ eas system
17 ton d-ring with solid polished titanium hitch
80% over rosewood injectors
Transgo tugger kit
dual disc tc
GTP38R
More to come
call me dan
dsberman94 is offline
post #4 of 9 (permalink) Old 01-03-2014, 10:49 PM Thread Starter
CSIPSD wet sanding destroyed my headlights....
post #5 of 9 (permalink) Old 01-04-2014, 01:18 AM
Meandog06
meandog06's Avatar
Then you obviously didnt start with and end with the right sandpaper, followed buy 3-4 stages of buffing. Theres no damage besides a crack on a plastic headlight that cant be fixed if you know what your doing.
meandog06 is offline
post #6 of 9 (permalink) Old 01-04-2014, 01:23 AM Thread Starter
I went and did a actor what VHT told me and it scuffed the hell out if my headlights. Yes I made the mistake of putting it on my headlights but I had no idea it fused so well.
post #7 of 9 (permalink) Old 01-04-2014, 01:53 AM
So breaks there is no reason to be upset, the stuff did wat it was ment to do, if I tint my lights I don't want it washing off....but like said above, sand and buff and you really should need new lights..
koda22 is offline
post #8 of 9 (permalink) Old 01-04-2014, 02:27 AM Thread Starter
Straight edge razor is the way to go! Take it from experience... I actually have some awesome light coming out of there. Probably upgrading bulbs soon.
post #9 of 9 (permalink) Old 01-11-2014, 01:25 PM
I did some of mine too dark so I wanted to start over. I literally just took a rag with brake cleaner on it and the stuff wiped off. Seemed easy to me and my tail light looked new after.
Sent from AutoGuide.com App
2012 F250- 4.5in. lift, 24x12 rockstar II's painted tuxedo black, 37x13.50x24 M16's, KEM race tunes, 5in. exhaust, and much more.
DillonC is offline
Closed Thread
