alt going, better replacement? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 02-24-2013, 02:14 AM Thread Starter
ok so i noticed my volt gauge is starting to read less than normal tonight, i figure my alt. is on its way out. I'm thinking of running an electric plow setup on my truck sometime soon along with lights and onboard air, therefore im considering going with a higher than stock alternator. Anyone have any good suggestions as to where to get a good alternator from?
Should i go to ford and buy the ambulance package unit and will i need to upgrade my wiring in the process?
1995 F-250, RCLB. 5-speed, Rebuilt trans. South Bend Clutch OFE-K. AFE Intake, Exhaust:Stainless MBRP/Flo-Pro mutt. Oil temp, Boost, Pyro gauges. Spooled D60 swap, 2.25 PMF RSK w/SD X codes. Fisher MM1 Bigger wheels/tires coming soon hopefully.
Jeremie444 is offline
post #2 of 7 (permalink) Old 03-02-2013, 04:46 PM
iowacornfarmer's Avatar
Re: alt going, better replacement?
I have a 95 alternator that works great, if your interested.
1992 F350 RCLB - 12 valve Cummins - 7.3 intercooler - NV 4500 - M&H 4 fuel pin - 4407 T-Case - PMF 3.5 RSK - Fully LINE X'd - Tom Woods Custom Rear CV Driveshaft.
iowacornfarmer is offline
post #3 of 7 (permalink) Old 03-02-2013, 06:33 PM
40 lug nuts
Snake's Avatar
DC Power without a question.
BULLETPROOF DIESEL
Biofuels Technologies
1A Auto
2005 F-250
Snake is offline
post #4 of 7 (permalink) Old 03-04-2013, 08:03 PM
I went with Leece-Neville 200 amp single unit it's a T model and bolt right into the stock location, fully rebuildable.
jrc
Tan white tan 97 ECLB, D60 RSK SD springs front, airs bags rear, E4OD 4:10, intake, DP 4 exhaust
Red 97 F250 CC 3:55, D60 Air Locker front, 175/80s, T500, TW files, Tymar, SD I/C, 6.0 fan, E-air, E-Fuel, RSK, SD springs front/rear, 145 litre rear tank (now ZF-5
JCart is offline
post #5 of 7 (permalink) Old 03-04-2013, 08:06 PM
Administrator
Zmann's Avatar
I would get the batteries tested first and check all the connections
I sure Like DC Power but get a time estimate for shipment
DTR's Donation page
RIP DTR Ron
Zmann is offline
post #6 of 7 (permalink) Old 03-05-2013, 09:52 PM
There can be only one
highlandre's Avatar
I had my local shop rebuild mine. They did a great job and I know where to go if I have problems.
That and he's my cousin and doesn't charge me for the parts.
2002 F250 CCSB 7.3L
AFE Stage 2, Muffler delete, Zone Offroad Nitros, dual SS,305/55/20 Trail Graps, SSBC brakes, TS Wildman, Autometer gauges, 6.5" Lift, '11 TG step/camera, Pioneer AV4400BTH, International Badges
highlandre is offline
post #7 of 7 (permalink) Old 03-06-2013, 03:30 PM
'05 Excursion
Term3's Avatar
Yah, I'm on pins and needles waiting for my 300 amp.
Sent from AutoGuide.com App
Term3 is offline
