Led signals in 05-07 lights...resistors...? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 15 (permalink) Old 01-30-2013, 09:39 PM Thread Starter
Anyone have led signals/running lights in their 05-07 lights ?
Did you have to use resistors ? I know some applications need them and others don't..
ps3 online: kennyfcknpowers
tturbonegro is offline
post #2 of 15 (permalink) Old 02-02-2013, 11:29 AM
Flatulent entrepreneur
IMO, the bulbs are cheap. Swap your turn signal bulbs. If you do one and it blinks faster, like a bulb is out, swap the original back in and order a resistor before installing all the way around. I'm guessing you'll need 1 for each side. Hope this helps.
Sent from AutoGuide.com App
Wannabitawerm is offline
post #3 of 15 (permalink) Old 02-05-2013, 09:44 PM Thread Starter
Re: Led signals in 05-07 lights...resistors...?
Gotcha, will do, thanks. I got the ones that have a constant white for a clean look but blink orange for the law.
post #4 of 15 (permalink) Old 02-06-2013, 02:37 AM
Juniorssrollin's Avatar
Screw the resistor, just asking your problem. My truck has leds all the way around and I went with a LED compatible flasher. Part number EP27 at your local autozone or advance
Sent from my DROID RAZR using AutoGuide App
2005 CCLB FX4- studded, blue spring, 6.4 banjo bolts, 6 inch lift and 35" Nittos
Juniorssrollin is offline
post #5 of 15 (permalink) Old 02-06-2013, 05:31 PM
'05 Excursion
Term3's Avatar
Agreed, a digital relay is THE way to go.
Term3 is offline
post #6 of 15 (permalink) Old 02-11-2013, 12:17 AM Thread Starter
What is that, a relay that replaces the factory one that is capable of handling the led bulbs ?
post #7 of 15 (permalink) Old 02-11-2013, 06:19 AM
Yes look up that part number EP27
post #8 of 15 (permalink) Old 02-11-2013, 09:40 AM
I will check that out myself. Been reading up but haven't gotten around to pulling the trigger.
post #9 of 15 (permalink) Old 02-16-2013, 09:50 AM
Yep. Ep27. Worked like a champ. It was a bear getting to the relay but it blinks like a champ.
post #10 of 15 (permalink) Old 02-17-2013, 12:25 AM
Work&Play's Avatar
Where is the relay ?
Andy 2007 4X4 F350,6.0 PSD, Lariat, CC, DRW, 9' Knapheide body, stainless steel ladder rack, SCT with custom tunes, Banks turbo back, ARP's, ITP RR, Airdog II, Powermax with Billet Wheel, Firestone air bags, Autometer gauges( pyro,fuel pres,water temp,boost,trans temp), CCV mod.
Work&Play is offline
