Solar charger for car batteries? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 9 (permalink) Old 01-12-2013, 09:13 AM Thread Starter
US Army
ArmyGuy45's Avatar
Anyone have any experience with this product or something similar?
Keep your car battery charged wherever it is with the Battery Tender 10-Watt Solar Charger. A 10-watt solar panel provides power to your 12 volt car battery when another power source isn't available. A built-in three-step automatic microprocessor controller keeps the battery from overcharging. The Battery Tender 10-Watt Solar Charger is completely portable!
The Battery Tender 10-Watt Solar Charger has all high quality features you expect from Battery Tender battery chargers. It is sparkproof and has a temperature compensation sensor. Battery Tender backs up the Battery Tender 10-Watt Solar Charger with a 5 year warranty.
The Battery Tender 10-Watt Solar Charger is convenient for people who store their vehicle where there is no power source, like a carport or shelter. As long as you have sunlight, your vehicle's battery will stay charged! The lightweight Battery Tender 10-Watt Solar Charger can easily be carried with you on extended trips to keep your car battery charged anywhere.
The Battery Tender 10-Watt Solar Charger works with all lead acid, sealed maintenance free and gel cell batteries. Use it on 12 volt batteries on cars, RVs, trucks, tractors, and recreational vehicles.
Battery Tender solar panels are the only panels available with a built-in charge controller to prevent overcharging! No other battery trickle charger works like a Battery Tender battery charger.
Product Specifications:
26" x 16" x 0.875"
5.5 lbs
12 V Nominal Voltage 540 mAmps
Temperature Compensation Sensor
Sparkproof
5 Year Warranty
Battery Tender 10-Watt Solar Charger, solar power battery charger, car battery charger
I guess this is for those who let their truck sit for long times or take it camping. Would this be a good item to add to the SHTF list?
US Army 2005-Present
2000 Ford F350 7.3L 4dr 4x4 long bed
NRA/SAF/AZCDL Life Member
"The role of Government is to protect equal rights, not to provide equal property." - Inspired by W. Cleon Skousen, The 5000 Year Leap.
The most important right is property rights. If you don't have the final say so with your property then what do you have?
ArmyGuy45 is offline
post #2 of 9 (permalink) Old 01-12-2013, 02:15 PM
'05 Excursion
Term3's Avatar
My way of thinking is when something is called a tender that it has barely enough power to maintain a battery sitting there unused. So if your drawing power out of the battery I don't think 10 watts is anywhere big enough to keep it topped up. Every time I drive by one of those solar powered road information signs with the HUGE sets of panels on top I have an almost uncontrollable urge to mount those panels to my Excursion's roof rack. Too bad most of them have a wireless theft protection system. ROTFLMAO.
Sent from my iPhone using AutoGuide.com App
Term3 is offline
post #3 of 9 (permalink) Old 01-13-2013, 06:06 AM Thread Starter
US Army
ArmyGuy45's Avatar
Re: Solar charger for car batteries?
Now that would be awesome to see!!!!
post #4 of 9 (permalink) Old 01-13-2013, 01:55 PM
coryjones's Avatar
It would be .84 amps not enough to maintain one large battery let alone two. If you want to do it look in to rv solar chargers.
2004 EX valved blistens 08 mirrors 05 headlights 20x13.5x37 5" SCT LiveWire flopro exhaust coolant filter 6.4 banjo bolts 8 1/2 western V plow.
coryjones is offline
post #5 of 9 (permalink) Old 01-13-2013, 01:56 PM Thread Starter
US Army
ArmyGuy45's Avatar
Well, would you worry about over charging?
post #6 of 9 (permalink) Old 01-13-2013, 09:03 PM
coryjones's Avatar
A tender will shut off when a full charge is reached.
post #7 of 9 (permalink) Old 01-16-2013, 03:22 AM
I have a year 2000 7.3 Ford diesel. 205k miles runs perfect, but at 40 degrees if i don't plug it in it does not crank. At 10 degrees now, if i don't crank it every 3 hours it does not crank. Glow plugs? or fuel?
cmbjr is offline
post #8 of 9 (permalink) Old 01-16-2013, 03:32 AM Thread Starter
US Army
ArmyGuy45's Avatar
Welcome Newb.
Does your area have winter fuel to prevent gelling? Also you can cycle the glow plugs like 3 or 4 times before crank to help warm up the engine.
post #9 of 9 (permalink) Old 01-16-2013, 01:00 PM
Thanks I'll check. and i'll cycle the plugs.
cmbjr is offline
