Running board courtsey lights - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 12-18-2012, 01:35 PM Thread Starter
jdereu's Avatar
I have a 2000 f-250 crew cab and i am looking to install running board courtsey lights that only come on when the door is open. My question is where do i tap into for power?
jdereu is offline
post #2 of 4 (permalink) Old 12-19-2012, 03:26 AM
Always Learning
Re: Running board courtsey lights
You want to tap onto the Door Trigger Wire. On your truck it is a Black wire with a thin blue stripe. It can be found in a 40 pin plug on the firewall behind the Drivers Dash. This wire will only show 12 volts when any of the door are opened. Use a test light to verify the wire.
bknight187 is offline
post #3 of 4 (permalink) Old 12-19-2012, 01:18 PM Thread Starter
jdereu's Avatar
what general area will i be looking i read that it could be found behind the driver side kick panel is that true too?
jdereu is offline
post #4 of 4 (permalink) Old 12-19-2012, 11:30 PM
Always Learning
Yes it can be found in the drivers kick.....follow the wires up and you will see a black 40 pin plug.
