How to create a "thank you" random flash circuit like the big rigs - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 11-29-2012, 10:20 AM Thread Starter
Hey guys, I do a bit of towing thru the mountains around semis and they are some of the most courteous drivers around.... Just for cool factor I'd like to make a circuit to random flash all my lights like some semis can do when they give you the "thank you" for letting them pass.... Anybody know how to do this? Id like to flash everything except low/high beams.
Just a cool factor modification id like to do, not looking to make a constant strobe like cop cars just a random order flash like the big boys do when they say thanks
Sent from my iPhone using AutoGuide.com App
01 F250 CCSB, BTS, ICON 4" on Bilsteins, 35" Toyo MT on 18" Fuel Hostage, DP F6 Tuner, 6637, 5" pipe, AIH delete, EBPV Delete, Recon Smoked lights all around, 35W Retro HIDS,
HEROS NEVER FALL.... THEY EARN THEIR WINGS.... RIP LCPL JASON D. HILL - IRONMAN, YOU WILL NEVER BE FORGOTTEN. SEP 18 1990 -JUNE 11 2011
pbguy420 is offline
post #2 of 10 (permalink) Old 11-30-2012, 02:21 AM
Juniorssrollin's Avatar
I always just very lightly tap my brakes twice just to engage the lights. Most of the time I'll get one in return
Sent from my DROID RAZR using AutoGuide App
2005 CCLB FX4- studded, blue spring, 6.4 banjo bolts, 6 inch lift and 35" Nittos
Juniorssrollin is offline
post #3 of 10 (permalink) Old 11-30-2012, 12:51 PM Thread Starter
That's what I do now or if they are in front flip my lights off then back on real quick... I just want to make this work for that coolness factor
pbguy420 is offline
post #4 of 10 (permalink) Old 12-03-2012, 12:00 AM
Always Learning
Re: How to create a "thank you" random flash circuit like the big rigs
My .02.......When I tow my gooseneck I just use my 4 ways flashers. It does the same thing. It will flash all you running lights without having to turn off your head lights. I just hit the botton....let them flash two times....then hit the botton back off. Rigs do it because they have a switch on the dash to turn power off to the trailer. So they just flip the power switch to the trailer off twice. If you look at a rig, tractor lights do not flash. When they pass, as soon as they signal to come in your lane....two quick high beam flash's.
If you wanted to put a switch in like rigs have you need to find the wire coming back the frame rail for the parking lights. Cut it and run to a switch. Then when you flip the switch your tail lights/trailer lights(as your trailer plug is wired into the tail lights) will flash. But flashing your 4ways does the same exact thing....and takes no time or money.
bknight187 is offline
post #5 of 10 (permalink) Old 12-03-2012, 12:11 AM
Administrator
Zmann's Avatar
10-4 on that
DTR's Donation page
RIP DTR Ron
Zmann is offline
post #6 of 10 (permalink) Old 12-03-2012, 03:45 PM Thread Starter
That makes sense thanks
pbguy420 is offline
post #7 of 10 (permalink) Old 12-03-2012, 11:23 PM
Bigbody250's Avatar
i use my flashers too.
2012 F-250 Crew Cab SB Diesel - White Platinum Metallic - AFE - 5" MBRP - Spartan - AMP
2005 F-250 Crew Cab SB - Dark Copper Metallic - Lifted & Tuned (SOLD)
2000 F-250 Crew Cab SB - Oxford White - Lifted & Tuned + Audio/Video (SOLD)
Bigbody250 is offline
post #8 of 10 (permalink) Old 12-05-2012, 12:29 PM
NEVRNF's Avatar
You can do it all in the cab. Remove the headlight switch. Find the wire that feeds the parking lights. Cut it and add a switch. Just make sure you have the correct one as there are 2 wire that are hot in the parking light position. One is the dash lights. Move the dimmer up and down to make sure you are not on that one.
Tony
02 Excursion CR conversion with a few go fast parts
The truck
should have built
FOR SALE
NEVRNF is offline
post #9 of 10 (permalink) Old 12-05-2012, 09:41 PM
Always Learning
You could do that....but it will flash the front parking lights also....which is the same exact thing as turning the flashers on....
post #10 of 10 (permalink) Old 12-12-2012, 01:19 PM
NEVRNF's Avatar
Who cares if the front lights flash.
Tony
The truck
should have built
FOR SALE
NEVRNF is offline
