Are traction bars, or ladder bars better? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 05-05-2008, 03:23 PM Thread Starter
I need to install something on my truck to keep it from twisting the axle. I've heard that ladder bars are better, because they lock the pinion in place. I've also heard that a single set of traction bars under the axle is better, and that they use the spring as a sort of four link setup.
Any opinions?
Sean
99 F350 CCLB
skav is offline
post #2 of 7 (permalink) Old 05-05-2008, 11:26 PM
Oooo, White Lightning !
Dieselboy's Avatar
Re: Are traction bars, or ladder bars better?
Ladder or traction bars..........Essentially the same thing
THat being said, If your gonan make em then do one bar to the bottom of the axle housing and one to the top, join em at the frame mount.........
Much more effective then a single bar
If your gonna buy them, I know that Fabtech makes a nice set of floating bars
Im not to up with the floating bars, dunno what the plus is over fixed
Hope this helps
Race truck
2002 F-350XL RC/LB
NADP Race Trans/PCS'd
Lowered w/ traction bars
Unlimited 450/400s
S475 on Irates mount
TE 17* with Gen3
DI Headers
Dieselboy fuel system
[email protected]
599.3 on BDs dyno
Tow pig
2000 F-250XLT EC/SB
Tuned
Exhaust
Intake
Dieselboy is offline
post #3 of 7 (permalink) Old 05-05-2008, 11:28 PM
Dieselboy's Avatar
Here check this out
https://powerstrokenation.com/forums/...ead.php?t=7180
pontiacross has a very clever way of mounting them, requires no welding to the axle housing
The ones Im fabbing for my truck are gonna use the same setup
Also check out urbanwheelers, BTW urban some of the nicest welds Ive seen !
Race truck
2002 F-350XL RC/LB
Unlimited 450/400s
TE 17* with Gen3
DI Headers
[email protected]
599.3 on BDs dyno
Tow pig
2000 F-250XLT EC/SB
Tuned
Exhaust
Intake
post #4 of 7 (permalink) Old 05-06-2008, 02:27 AM
flightmeck's Avatar
I know for the price i would go traction bars. You should take a look at Jesse's track bars at farmboyfabrications.com. I know a lot of people are running them and like them.
flightmeck is offline
post #5 of 7 (permalink) Old 05-06-2008, 02:44 AM
Built by BDP
SEOHPowerstroke's Avatar
Bean is in the process of making some to sell, I have a set on my truck now. Maybe he or I can post some pics soon.
'99 Super Duty Pullin Truck with a trick 6.7L twin turbo CR built by BDP
SEOHPowerstroke is offline
post #6 of 7 (permalink) Old 05-30-2008, 01:27 AM
Built by BDP
Here are a couple pictures of the BDP ladder bars.
post #7 of 7 (permalink) Old 06-01-2008, 01:32 AM
urbanwheeler's Avatar
just saw this, thanks dieselboy. i would go with ladder bars, i had quite a few guys interested and had trouble with the water cutter here in town. i have found another source for bracket cutting, but i am looking into a way to build a mount that requires no welding and still be a full ladder bar. if you are looking for ideas i have pics in my webshots.
'96 f-250, auto, shackle flip, solid axle, rsk, high/crossover steering, 3.73's, true trac's front and rear, trac bars, gt4202, 7.3 ic, idm mod, ccv mod, A1000, 4-line DIY Gen3, dual ipr's, casserly 350/200's, arp studs, 910's, pushrods, elec. fan, 2-stage nitrous, fluidampr.
[SIGPIC][/SIGPIC]
urbanwheeler is offline
