Upfitter Switches - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 14 (permalink) Old 04-13-2011, 11:10 PM Thread Starter
F-25000's Avatar
Upfitter Switches
I was wondering if anyone has tried to put upfitter switches in the cubby hole in 1999-2004 trucks? if any one has pictures that would be awesome. I would really like to put them in my truck.
thanks for any info guys
2004 F-250 regular cab long box, 6.0 w/ 6 speed, 4" turbo back exhaust, airaid airfilter, SCT, Sinister coolant filter, ARP studs, EGR delete, gauges- sold
2010 F-350 crew cab short bed Lariat. 6.4l with auto trans. Deleted and tuned.
Dylan
F-25000 is offline
post #2 of 14 (permalink) Old 04-15-2011, 07:06 PM
novakid69's Avatar
Re: Upfitter Switches
I put them in my 03 and made a filler panel for the rest of the cubby hole. there is a spot in the fuse box that has the same plug as the upfitters, I simply plugged the upfitters in and moved the 2 pins out of the factory connector into the upfitter connector.
2003 F250, 6.0 SOLD!
2011 F350 CC, SB, 6.7 Lariat! Icon, BMF, Toyo, AMP Steps, painted grill surround...
2006 F350 CC, LB lariat dually... Icon leveling kit, straight pipe, 22.5s
novakid69 is offline
post #3 of 14 (permalink) Old 04-16-2011, 07:37 PM
too broke to play
Cmonster's Avatar
novakid69
What is the oval switch to the left of the upfitter switches? I wondered what went in that slot.
2003 F-250, CC, SB, 4x4, 7.3, 6 speed
Cmonster is offline
post #4 of 14 (permalink) Old 04-16-2011, 08:56 PM
Reloading
Critical's Avatar
it's for the peddle adjustment.
America Land of the free.*
*Some restrictions may apply, void where prohibited.
Critical is offline
post #5 of 14 (permalink) Old 04-17-2011, 03:41 PM Thread Starter
F-25000's Avatar
how did you mount the switches into the cubby hole?
Dylan
F-25000 is offline
post #6 of 14 (permalink) Old 04-18-2011, 05:17 PM
novakid69's Avatar
I pulled the switches out of the surround, then put it in place, marked it and dremeled where the tabs go and it just clipped in
post #7 of 14 (permalink) Old 04-18-2011, 07:38 PM Thread Starter
F-25000's Avatar
cool thanks for the pictures
Dylan
F-25000 is offline
post #8 of 14 (permalink) Old 06-19-2011, 06:29 PM
Could you just install the entire 05+ lower dash assembly to the 99-03 for a cleaner factory look?? Also, how hard would it be to integrate the factory trailer brake controller to our trucks?? Thanks for any help
-- Ryan
Lifted94XLT is offline
post #9 of 14 (permalink) Old 06-21-2011, 03:39 AM
Modded by a Chevy Express
Alberta 7.3's Avatar
The 05-07 lower center panel fits with a bit of trimming of the plastic support bars of the dash frame. It would be next to impossible to install a TowCommand on an older truck, since it is patially integrated to the 05+ instrument cluster, requires a new master cylinder, and the PCM requires a re-flash.
96 F250 SC/SWB/4X4 XLT Just a 7.3 with a bunch of the usual bolt-on crap
08 F350 CC/LWB/4X4 DRW Lariat
Alberta 7.3 is offline
post #10 of 14 (permalink) Old 05-29-2013, 02:40 AM
Cowboy Up's Avatar
Garage
What do you mean by moving the two pins from the factory connector to the upfitter connector?
Lost to an accident
2002 F-350 CCLB Lifted on Forces
Cowboy Up is offline
