Traction Bars - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 28 (permalink) Old 04-30-2008, 11:58 PM Thread Starter
Busy Busy
Marty's Avatar
Traction Bars
I plan to make my own here soon for my truck and I just wanted to know what the idea behind the length of the bar was and how long it should be.
This is going to be on a stock suspensioned truck and I know that tire size does not matter at this point, but they're only 285's. It'll be on a crewcab short bed truck w/ a w/b of 156" but I don't think that matters.
I basically want someone to tell me how long the bar should be, and why...
(The Green part). Like my MS Paint drawing at work?
443.553.9234 - 410.392.3262
Elkton, Maryland
2005 F450 - Tow Bitch
Marty is offline
post #2 of 28 (permalink) Old 05-01-2008, 12:58 AM
Hacksaw Engineer
Trapper's Avatar
Re: Traction Bars
Find the trucks center point of gravity, by balancing the truck with 4 large jacks and when the truck can only stay barley on 4 points, find the middle of that point and that should be your center point. Draw yourself a green line from that point to your axles and you should get an idea where you brackets should drop down and how long.
2000 XLT 4x4 LBCC 6 speed BHAF mod DI chip. 4inch exhaust and gauges.
Trapper is offline
post #3 of 28 (permalink) Old 05-01-2008, 01:03 AM Thread Starter
Busy Busy
Marty's Avatar
Re: Traction Bars
Hmm illustration of how to do this? lol
Elkton, Maryland
Marty is offline
post #4 of 28 (permalink) Old 05-01-2008, 01:54 AM
Cummins Power
mech2161's Avatar
Re: Traction Bars
Start with the truck on 4 stands. Keep moving the stands together till you can easily tip the truck equally front and rear. The middle between the stands is the center of gravity.
Kevin
12v CONVERSION IN PROGRESS, Special thanks to:
South Bend Clutch, MOTORSPORTSSUPPLY.COM, Pure Diesel Power & Performance, Carson Stauffer Diesel Service, Weston Shupe, zstroken
mech2161 is offline
post #5 of 28 (permalink) Old 05-01-2008, 02:57 AM
What else?
smokyred's Avatar
Re: Traction Bars
First off, nice drawing.
I made mine in the same plane as the rear section of my 2 piece driveshaft. They came out being just over 6 1/2 feet long on my SCLB. I do have my rear mounts canted slightly rearward, and my front mounts are also canted slightly rearward, FWIW.
Mine work, plain and simple! I took 15 minutes to mock it up, and the engineer at work took about 45 minutes to make up a nice drawing and all on his CAD software to tell me I was right where I needed to be.
Dave
smokyred is offline
post #6 of 28 (permalink) Old 05-01-2008, 04:58 AM
Grumpy Old Bitter Bastard
389SixPack's Avatar
Re: Traction Bars
Marty, I don't have dimensions for you. Here are a couple sites to help ya out.
http://www.raceglides.com.au/TechInfo.htm
http://www.4x4wire.com/jeep/tech/susp/axlewrap/
http://www.4wheeloffroad.com/techart...t_2/index.html
And some pics from a PSN member - http://www.mcspadden.cc/ladderbars.html
aka - Grumpy .. aka - Bubba Grump .. aka - Bubba .. aka - Grumpy Old F... . . A "slow" fatass 9K Dually.
389SixPack is offline
post #7 of 28 (permalink) Old 06-23-2008, 09:05 AM
Re: Traction Bars
I went ahead and measured it up for you Marty, and on my screen it's 5 3/16". lol
In the events section?
Southpaw is offline
post #8 of 28 (permalink) Old 06-23-2008, 10:57 AM
King Dingaling
TANK'S 250's Avatar
Re: Traction Bars
the exact measurement is 7'1".
TANK'S 250 is offline
post #9 of 28 (permalink) Old 06-23-2008, 12:36 PM
Re: Traction Bars
if running a single bar set-up what are you attaching the rear of bar to ? on my friends D-max he put a bracket on the bottom of the u-bolts for the springs but that won't work on the Fords.
thanks
Jay
daytondiesel is offline
post #10 of 28 (permalink) Old 06-23-2008, 01:38 PM
<- Sums it up
strokin_early_99's Avatar
Re: Traction Bars
I tried to match the angle of the drive line but wanted to mount to the frame where it flared out to full size. Mine ended up being 85" or 7'1"(the same as Tank mentioned). My hook Sat night was the first time I had no wheel hop.
Early99 CC LWB 4X4
Updated B codes, Modded H2E, Big oil, half filled block, studded, John Wood 4R100. 232K miles
Tows like a champ!
"Damn Larry, he passed us like a freight train passing a hobo!"
--Lisa P.
Just sold to Larry
2-17-2019: 97 CC LWB 4X4 7.3 with full banks kit, John Wood E4OD. 139K miles
strokin_early_99 is offline
