question on fuel tanks on F450 chassie trucks - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 03-31-2011, 11:35 AM Thread Starter
blead Ford Blue
gjoski515's Avatar
Send a message via Yahoo to gjoski515
Ok guys at the wife's work they are having problems with the fuel tanks, Ford is saying that the liner is deteriorating in the metal tanks, has this been a problem, and if the carp from the tank gets in to the fuel system it would screw the Injectors right, Ford is saying tanks are on back order and does anyone know if they make the poly tanks for these trucks? Should the wifes boss put up a huge fight, been replaced already once and the truck is a 06 F450, condition is loss of power and starving for fuel, they still need to do the fpr spring on the truck, and they use Ford filters
gjoski515 is offline
post #2 of 7 (permalink) Old 03-31-2011, 12:41 PM
Sponsor
Re: question on fuel tanks on F450 chassie trucks
Yes they do have a problem from 99 to 10 on the F450 and 550's with the tank deteriorating. They say they have it cured on the 2011's. You are correct that the tanks are on back order from Ford. I have a Titan tank in stock for your application. Pm me if you are interested.
Dan
SoGrand is offline
post #3 of 7 (permalink) Old 03-31-2011, 04:24 PM Thread Starter
blead Ford Blue
gjoski515's Avatar
From them being bad are the Injectors done now, should they have Ford test them?
post #4 of 7 (permalink) Old 04-01-2011, 02:22 AM
Stroked
Bobus's Avatar
We had our '00 F550 at our VFD have this issue.. I dropped the tank and took it in and had it media blasted, then had the tank inside recoated with a tank liner.. Blew out all the lines from the fuel Filter back.. all was done for less than 100 bucks.
Wit them being 6.0l trucks.. yeah i'd have the injectors tested..
'10 F150 STX 4x4
'03 F250 Ex-Cab 7.3l 4x4 Auto
Bobus is offline
post #5 of 7 (permalink) Old 04-01-2011, 02:45 AM
worked on a 6.0 450 with a stake body the owner complained that there was no power and the whole fueling system had to be replaced because of it from the tank to the injectors
02 f250 extended cab
mbrp 4in. turbo back into dual 6in stacks afe stage 2 intake 4in lift fabtech full floating traction bars 6 position TS chip autometer trans temp boost and egt guages
big johnson is offline
post #6 of 7 (permalink) Old 04-01-2011, 11:08 AM Thread Starter
blead Ford Blue
gjoski515's Avatar
Dam, the wifes boss won't like that, but what is Ford doing about this, is this coming out of your pockets? If so that sucks, the whole fuel system is expensive
post #7 of 7 (permalink) Old 04-23-2011, 07:01 PM
<---- my shop
vader's fury's Avatar
I have had many issues with this problem with our work trucks. We have about 45 05+ 450's in our fleet and at least 10 of them have had this issue. Have not noticed it with the -05 trucks. I have one outside the shop right now with this exact issue. Everything in fuel system from tank to inj has to be replaced. Currently tanks are on back-order through ford till June.
I am wondering..... does anyone offer a comparable aftermarket tank and has anyone used them?
Robert
2003 F-350 CCLB, 7.3, Auto
2000 F-450 Sold.....
vader's fury is offline
