Pyro Probe Thread Size.. The other side - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 03-30-2011, 07:19 PM Thread Starter
GoNavy!
DcMoore999's Avatar
What size is the thread of the pyro probe that connects to the fitting? I have a bung welded in my dp and I relocated my probe to the manifold.. Finally
Anyways I want to put a cap on that bung. I know it's not 1/8" NPT.
2000 F-250, RCLB, Auto!!
DcMoore999 is offline
post #2 of 10 (permalink) Old 03-30-2011, 07:21 PM
Big Plans
jhaddox's Avatar
Send a message via AIM to jhaddox
Re: Pyro Probe Thread Size.. The other side
ive always tapped mine to 1/8 NPT...couldnt tell you the size if its not that
08 ECSB 6.4
MPD, GOGO, No Limit, Rudys, ARP, PMF, Innovative, AFE, Recon, Fuel, Nitto, Bilstein
Fueled by...Fuel, lots of it
jhaddox is offline
post #3 of 10 (permalink) Old 03-30-2011, 08:34 PM Thread Starter
GoNavy!
DcMoore999's Avatar
I'm talking about the other side of the adaptor that the probe screws in... the other side I know is 1/8" NPT
post #4 of 10 (permalink) Old 03-30-2011, 08:56 PM
Lost Cause
Betaracer's Avatar
Caliper and thread pitch gauge might be your tools needed.
Why not just remove the entire sleeve and put a 1/8NPT plug into the bung hole. (Hehe Bung hole)
2016 F-350, FX4, CCLB, 6.7PSD, 7" OUO/ICON/FOX lift, 38x13.50-18 Toyo MT
Betaracer is offline
post #5 of 10 (permalink) Old 03-30-2011, 09:06 PM Thread Starter
GoNavy!
DcMoore999's Avatar
Well it's not really a bung that is welded it's the damn fitting.. I'm not to sure why they did it like that but they can suck it who ever it was.
post #6 of 10 (permalink) Old 03-30-2011, 10:52 PM
Big Plans
jhaddox's Avatar
what kind of gauge is it...the autometers just have a set screw you use on the probe
08 ECSB 6.4
jhaddox is offline
post #7 of 10 (permalink) Old 03-31-2011, 04:55 AM
Lost Cause
Betaracer's Avatar
I remembered I had an Autometer EGT probe in my box of left over/damaged/replaced parts. The end in question measured to 11M (.4300") x 1.25 (I don't have a TPI gauge at home), but that's not to say there isn't a common Imperial thread that converts. The nut holding the probe in requires a 5/8" wrench, and none of my metric wrenches fit properly. I will need to look at a 1/4" compression nut to see if it is the same.
post #8 of 10 (permalink) Old 03-31-2011, 01:07 PM Thread Starter
GoNavy!
DcMoore999's Avatar
Awesome.. I will see where I can get today on it.
post #9 of 10 (permalink) Old 04-01-2011, 02:20 AM Thread Starter
GoNavy!
DcMoore999's Avatar
I found a cap! It's a 1/4" flare fitting cap
post #10 of 10 (permalink) Old 04-01-2011, 02:44 AM
Lost Cause
Betaracer's Avatar
I was just going to say that. I had to go to our local NAPA franchise (also carries industrial supplies and parts) and they had the cap there.
