wheel spacer? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 04-29-2008, 09:49 PM Thread Starter
mikek4599's Avatar
wheel spacer?
MY question is,I just installed some Bushwacker pocket style flares today and in my opinion they stick out too much past my tires.I have 295/75/16's.I dont think the 1/4" spacers will do much.Has anyone used the 2" wheel adapters?Any pics of pocket style flares installed would be great.I'm just not sure if I like them.I think it might be the contrast of black flares on a yellow truck.
mikek4599 is offline
post #2 of 6 (permalink) Old 05-02-2008, 02:40 AM
bigd4me2's Avatar
Re: wheel spacer?
you can try freds, the spacer type is not the greatest type!
http://www.wheeladapter.com/home.asp
02 dmax cc dually 4wd "miss piggy" tow bitch, afe pr7, magnaflow, Kennedy lift pump, dual rail mount filters, PPE tunes
00 f350 srw rc=6100lbs
ats comp housing,bdp 1.0 exhaust,afe pr7,4in turbo back magnaflow,hx cross,di regulated return,bbha,dp hi,40,80e,120r,6.oh no cooler autometer gauges, dual rail mount filters
bigd4me2 is offline
post #3 of 6 (permalink) Old 05-02-2008, 06:45 AM Thread Starter
mikek4599's Avatar
Re: wheel spacer?
I was hoping I could find a 1/2 inch one but they are hard to find.The only place is ebay.
post #4 of 6 (permalink) Old 05-02-2008, 03:59 PM
Going Crazy
badluck_early99's Avatar
Send a message via MSN to badluck_early99
Re: wheel spacer?
I run a 2'' spacer with my wheels cuz the offset was a little off, but they stick out perfectly now and i have flares, not the pocket ones but the flares stick out about an inch further than the normal fender i think
1999 F250 PS 6spd, 37x12.50x17 ProComp Xmud, 06 Grill & Lights. DP tuner, Terminator Hpops, Garrett 42, Casserly B codes, FASS Fuel system by DI, H11's, ITP Reg Return W/Bowl Delete, Sknab 6oh Intercooler, DIY Intake, 4'' Exhaust, Itp OBA, Autometer boost and pyro, , ccv
-Richard-
badluck_early99 is offline
post #5 of 6 (permalink) Old 05-03-2008, 04:10 AM
bigd4me2's Avatar
Re: wheel spacer?
did you have to change your studs, or are you runnin an adaptor?
the problem with spacers is that somtimes they make your wheel/tires feel out of balance, and sometimes the lugs will loosen up. that been said, i am runnin a 1/4 inch spacer between my rear wheels on my chev for clearance between tires, and i'm not having any problems with it as of yet, and i do tow heavy with that truck.
bigd4me2 is offline
post #6 of 6 (permalink) Old 05-06-2008, 05:33 PM
Re: wheel spacer?
I have head putting locktite on the bolts helps keep the bolts from loosing up on you so you only need to check them at rotations
Toddy is offline
