99 bolt pattern - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 9 (permalink) Old 03-27-2011, 07:07 PM Thread Starter
OverFuelingForYourPlesure
pontiacross's Avatar
99 bolt pattern
is it possible a 99 f350 dually could have had the same bolt pattern as the OBS trucks?
I bought a set from a guy that said they were off a 99 so I could put them on a 02 axel i bought for for my pulling truck. I didn't have anything to measure them with when I picked them up, but went to put them on today and found out they are the old 8x6.5 bolt pattern
so I'm trying to figure out if he screwed me on just made an honest mistake when he sold them to me
Ross
2.6 modified street pulling truck "The Lone Stroke
-1996 f350, stock bottom end! swamps 400/400% injectors, swamps BFH turbo, swamps IDM, Swamps tunes, BTS oil, springs, studs, tubes, fuel system, water to air cooler, and much more...
-97 f350 4x4 CCLB tow rig
pontiacross is offline
post #2 of 9 (permalink) Old 03-27-2011, 07:29 PM
me2
Re: 99 bolt pattern
'99 to 2010 SDs have 114mm x 8 pattern.
The rims are hub centric and the rim ID changed a very small amount in 2008.
New truck.
08 F350 King Ranch
Long box CC 4x4
6.4 5R110
Soon to get a Cummins 6.7 transplant.
Old truck.
Red '99 2WD F250 CC SWB
3rd gen 325/610 Cummins, ZF6
Custom air ride suspension
me2 is offline
post #3 of 9 (permalink) Old 03-27-2011, 07:41 PM Thread Starter
Re: 99 bolt pattern
IIRC I think the daullys acually changed again in 05 to 8x200mm bolt pattern. are you sure the early 99's couldn't have had the old bolt pattern? I know there are quite a few other little things that were differant with them
Ross
post #4 of 9 (permalink) Old 03-27-2011, 07:45 PM
Recruit #211
RC4WD's Avatar
Re: 99 bolt pattern
my e99 srw runs the same pattern as the other '00-'10 trucks and haven't heard of anyone else running into lug pattern problem on e99 trucks.
e99 ec/sb 6spd 4x4 swamps 4pos, con ofe, airaid stage 2, ccv mod, ebpv delete, magnaflow 4" turboback duals,
autometer phantom II's, 38r, comp 910, h11s, and pushrods 327k and still kickin
next to come more fuel
Originally Posted by HotRodTractor
A 6.0 is a good choice - every boat needs an anchor.
RC4WD is offline
post #5 of 9 (permalink) Old 03-27-2011, 08:49 PM
WINNING
Countryboy07's Avatar
Re: 99 bolt pattern
All '99-'11 trucks are 8x170mm even the duallys through the F-350. The 450's and 550's are a different lug pattern.
I think you got screwed...
2002 VW Jetta TDI
Countryboy07 is offline
post #6 of 9 (permalink) Old 03-28-2011, 02:58 AM Thread Starter
Re: 99 bolt pattern
pretty much what I was thinking just wanted to make sure before I called the guy.............
Ross
post #7 of 9 (permalink) Old 12-16-2011, 07:01 PM
Re: 99 bolt pattern
I thought in 2005 Ford changed to 8 on 200mm?
1999-2004 were 8 on 170mm
my 1993 is 8 on 6.5
rose88 is offline
post #8 of 9 (permalink) Old 12-18-2011, 07:13 PM
rock blower upper
Re: 99 bolt pattern
my early 99 dually had the new 8x170 pattern.
03 7.3 sc 8' xlt, 4r100 4x4 was 03 2wd xl work truck, built what I couldnt buy
13 6.7 cc 8' 4x4
double-s-diesel is offline
post #9 of 9 (permalink) Old 12-18-2011, 08:11 PM
they call me tater salad
jawsfx4's Avatar
Re: 99 bolt pattern
[QUOTE=rose88;1719465]I thought in 2005 Ford changed to 8 on 200mm?
08 white cclb 4" straight pipe into 8'mitre cut black stack,dpf delete,egr delete,arp studs,6" fabtech lift,metal mulisha wheels wrapped im 37" toyos,sct running extremex,kenwood double din running two ten inch type r through a m1000,homemade front and rear bumpers, beamers hids
jawsfx4 is offline
