Interior LED COLOR CHANGE!!! - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 64 (permalink) Old 03-22-2011, 01:38 PM Thread Starter
powerstrokedkid87's Avatar
ok so after trying to read up on this, i finally decided to take the plunge and take apart every switch, button, accessory containing that generic green light color....I have taken apart everything including my AC/Heat control unit. My plan is to re-sodder all the Led's, and lights to make them red. All my window buttoms, aux switches, steering wheel controls, head light switch, fog switch, ect...pretty much everything but the radio only because im planning for a new one will have a red LED....Let me know what everyone thinks....il post pics up of the work in progress when i get home tonight......
BTW..if this is in the wronge section Mods feel free to move..thanks
powerstrokedkid87 is offline
post #2 of 64 (permalink) Old 03-22-2011, 01:41 PM
PETE ENGR PSD
Re: Interior LED COLOR CHANGE!!!
It should be pretty sweet. I've always wanted to do this, I just don't think I have the patience lol
KEVIN
2006 F-350 Kingranch 79,XXX
TAMU_PSD is offline
post #3 of 64 (permalink) Old 03-22-2011, 01:50 PM
The Stig
BFD99's Avatar
Send a message via AIM to BFD99 Send a message via MSN to BFD99
good luck, might buy one red LED to test it out, because i know you can't run RED leds on the dodges, it looks pink, because of the spectrum of light the LED produces and the green light filter that makes the lights show green with the regular incandescent bulb.
On edit: i know the blue works great on the dodge for sure, that's what i swapped all of my lights out too. Are you planning on using superbrightleds.com?
2006 Ram 5.9L 2wd Gogodiesel, Garmon's Diesel
2010 Dually 6.4L, Gogodiesel, KEM Tuned
BFD99 is offline
post #4 of 64 (permalink) Old 03-22-2011, 01:56 PM
6Leaker
jdc753's Avatar
Send a message via AIM to jdc753
subscribed, Take LOTS of pics, I would love to see how you get it all done. Main part I am worried about would be the steering wheel controls and the AC/heater controls (if you have the digital setup)
2005 F350 Crew Cab Long bed
6.0L / Auto 4x4
SCT X3 5" Magnaflow
4" RCD lift, a bunch of stereo gear and a computer
jdc753 is offline
post #5 of 64 (permalink) Old 03-22-2011, 02:09 PM
The Stig
BFD99's Avatar
Heres a place to get started. I know in my instrument cluster bulbs i used b8.5hp bulbs in blue, and neo-5 in my A/C controls, and i used the bulb, not the base, just the bulb and resistor to solder to my headlight switch. By using the LED there is no need to add a seperate resistor.
And i know this is for a dodge, but it will give you a good idea of what is involved.
How-To: LED Dash Conversion for 06-08 - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
BFD99 is offline
post #6 of 64 (permalink) Old 03-22-2011, 02:19 PM Thread Starter
i will most definitly take pictures and keep everyone updated, i do have the digital steering wheel and ac controls, so that should make for some nerv racking excitment.....
post #7 of 64 (permalink) Old 03-22-2011, 02:21 PM Thread Starter
thanks for the tips, i am planning on doing a custom cluster cover, but changing the bulbs also. And im using another electrical supplier for all the LED's. Im making sure i tested all the lights with a meter and making sure that they are all the same brightness that way theres nothing that stands out brighter than the other.....should be a cool mod when its all done...again thanks for the input..il keep everyone posted...have a feeling this is not gona be a one day mod though.
post #8 of 64 (permalink) Old 03-22-2011, 11:05 PM
Reppin' the 6.4L
SickStroke6.0's Avatar
SICKS-O changed his to blue, and I think it looks sweet. red should look killer as well! I'm partial to the green though.
Blake
Looking for a second 6.4L....
2008 F-250 CCSB King Ranch 6.4L
4" Rough Country Lift, Dual Steering Stabilizers, 20x10" XD Diesels, 35x12.50x20" Mickey Thompson MTZ's, Line-X, 15% Tint, MBRP 4" Cool Duals w/ 6" Tips, S&B Intake, Flo-Pro EGR Delete and Elbow, MBRP CAC Tube
SickStroke6.0 is offline
post #9 of 64 (permalink) Old 03-23-2011, 12:30 PM Thread Starter
see if would like the green if it was a little brighter...to me the green looks like a dull bland color...just my opinion
post #10 of 64 (permalink) Old 03-23-2011, 03:03 PM
The Stig
BFD99's Avatar
i still think blue would be the best bet, because of the green color spectrum the Blue LEDs should be brightest, not saying the Red ones wont work, I just know they don't on the Dodges, they show up pink.
BFD99 is offline
