Key dinger?? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 15 (permalink) Old 04-22-2008, 09:06 PM Thread Starter
All Talk, No Walk?
RSieck's Avatar
Send a message via AIM to RSieck
Key dinger??
What wire do you cut to disable the key dinger when the door is open? IIRC its a black and pink wire... Just wanna make sure before I get the snippers going..
Early 99 PSD 4x4, Goerend Billet Tranny & Converter, GREEN
RSieck is offline
post #2 of 15 (permalink) Old 04-22-2008, 09:21 PM
Re: Key dinger??
I taped the contact on the key cylinder. Not sure which wire.
NWSUPRD is offline
post #3 of 15 (permalink) Old 04-22-2008, 09:22 PM Thread Starter
All Talk, No Walk?
RSieck's Avatar
Re: Key dinger??
How do you pull the ignition switch out? I tried a little but got nothing.
RSieck is offline
post #4 of 15 (permalink) Old 04-23-2008, 03:22 AM
OEM Moderator
Tom S's Avatar
Re: Key dinger??
If it is like the OBS you use an allen wrench or similar in the hold on the bottom side of the column below the cylinder. A little tape over the contact and walla.
Tom
Tom S is offline
post #5 of 15 (permalink) Old 04-23-2008, 05:49 AM
Banned
Send a message via Yahoo to blk99
Re: Key dinger??
I pulled the contact thingy off and then taped it....
blk99 is offline
post #6 of 15 (permalink) Old 04-24-2008, 01:19 AM
Custom Trailer Sales
TrailerHauler's Avatar
Re: Key dinger??
I cut that black and pink wire and mine stopped, much easier than playing with balls in ignition switches!!
1999.5 F350 PSD CC Dually 05' Conversion
Stage I's - Gearhead Tuning - BTS - PCS
F550 rear suspension
1999.5 F350 PSD S/C 6spd Dually
R.I.P. Will Iott - "This ain't no practice run"
TrailerHauler is offline
post #7 of 15 (permalink) Old 04-24-2008, 01:21 AM
Got Whistle?
crack_7.3's Avatar
Re: Key dinger??
where is this black and pink wire located? in that accordian lookin grommet in the door?
08 F350 Lariat
Blacked
IDP tuned SCT
crack_7.3 is offline
post #8 of 15 (permalink) Old 04-24-2008, 01:59 AM
Re: Key dinger??
nope, it's in a bundle under the steering column. I think in a yellow tube not sure though
post #9 of 15 (permalink) Old 04-24-2008, 03:20 AM Thread Starter
All Talk, No Walk?
RSieck's Avatar
Re: Key dinger??
Cut it a little bit ago, and no more annoying dinger!!!
RSieck is offline
post #10 of 15 (permalink) Old 04-24-2008, 03:46 AM
Send a message via AIM to JohnT
Re: Key dinger??
To get the cylinder out of a SD you take the lower cover of the steering column off, use a small allen wrench in the hole underneath and when the truck is in the run positon you can pull the ignition cylinder out. Then you just pull the wire off and tape it your done and it can be put right back to stock in seconds.
99 PSD 4x4 CCLB
05 PSD 4x2 RCLB
JohnT is offline
