gauges - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 04-19-2008, 10:50 PM Thread Starter
gauges
i bought me some gauges a boost a trans and a pryo i was wondering were the best place is to put the boost and how wer does the trans go and how do you hook it up its my first time with the trans dont mean to sound stupidif anyone can help me i would appreiate it thanks
1999 ford super duty ex cab short bed 4x4 dp-tuner f-5 lomp mod,80 econ,100,120 race,140 aggresive 4inch exaust to 6-inch tip non-wastegated housing upgrade from bts di-performance crossover line di-performance fuel tank mixing delete autometer gauges boost,trans,pyro custom made cold air intake.
big bad stroker is offline
post #2 of 6 (permalink) Old 04-19-2008, 10:55 PM
2nd class citizen
1snotrocket's Avatar
Re: gauges
put the pyro in the driver side exhaust manifold near the flange.boost gauge i ran a vacum tee at the map sensor.you can install your trans temp gauge sender at the check port in left side of trans by the shift indicator you'll see a brass plug.
2003 CRW CAB LB 4X4 6SPD,AFE STAGE 2,38r,DP TUNER,4'' MBRP,FASS 15,Farmers Disel Performance 160/100 injectors,ITPREG.RETURN,TERMINATOR
2001 crw cab short bed auto 4x4 5"exhaust afe stg 2,f6,jw trans,terminator,cass. stg2's,itp reg return,fuel lab pump.
1snotrocket is offline
post #3 of 6 (permalink) Old 04-19-2008, 11:13 PM
RDRCM
CooterBrown's Avatar
Re: gauges
Could someone call Joe and let him know there is a gauge thread that he has not posted in. He won't answer when I call?
#49
Sold
2006 Almighty CumminGs
CooterBrown is offline
post #4 of 6 (permalink) Old 04-19-2008, 11:27 PM
Banned
Send a message via Yahoo to blk99
Re: gauges
are you asking what order is best to put them in the pod or where they are all hooked up at??
blk99 is offline
post #5 of 6 (permalink) Old 04-21-2008, 03:45 PM
Village Idiot
southmike's Avatar
Re: gauges
actually joe had a good pic of that trans port somewhere ..
and most people do have an order preferance top to bottom.
if they are installed on the pillar...ie you want the egt to be the easiest to see.
southmike is offline
post #6 of 6 (permalink) Old 04-21-2008, 05:25 PM
<<< THE GAUGE WHORE...
CSIPSD's Avatar
Re: gauges
Here is a few shots... You can make up a Brass T for the boost and put it in your Map line, or you can drill and tap the Y pipe. You can also use the Intake Air Heater port for boost as well... Light blue in the second pic...
Pyro, In the manifold, Drill, tap and install. No need to vac, no need to grease the bit. Drill, Tap and install. Third Pic is the drill and tap, fourth is drill and clamp...
Tranny, In the test port on the drivers side, just above and infront of the shift linkage.
Joe
CSIPSD is offline
