Directions on how to replace ball joints and axle seals on my Dana 60? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 04-18-2008, 05:51 PM Thread Starter
Junior Mint
I recently stuck a Dana 60 under my truck and it's loose as a goose.
I've never rebuilt a front suspension (balljoints, axle seals, and all those brackets) but I figure it can't be too hard.
Does anyone know where I can find some directions to install this crap or do I just yank it apart as it comes?
Thanks.
Suns_PSD is offline
post #2 of 5 (permalink) Old 04-18-2008, 06:03 PM
R.J.'s Avatar
Re: Directions on how to replace ball joints and axle seals on my Dana 60?
Here is a link to a ball joint write up.
http://seven.three.superdutypsd.com/...Joint_Write_Up
The write up was done by fellow PSN member jinco
Bob
02, F250, 4x4, CC, Auto, Warn manual hubs, Line-X, Isspro Pyro, Boost, Trans temp and Fuel pressure gauges. Wicked Wheel, AIS intake, John Wood valve body, BrakeSmart, DuraFlap Mud Flaps, 6.0/31 row tranny cooler, ITP Regulated Return Kit, Dieselsite coolant filter & 203 thermostat. Cat ELC coolant, MagnaFlow premium exhaust.
R.J. is offline
post #3 of 5 (permalink) Old 04-18-2008, 11:46 PM
<-- it's like that
TDS has a nice article with pics. Only....... it's at TDS
There's always a catch.
Curtis
2002 F-250 PSD
Gambling with 250/200's on PMR's.
478hp/851tq on Haller's dyno - 7/28/12
Your connection to the
Pocket is offline
post #4 of 5 (permalink) Old 04-19-2008, 03:51 AM
Hoosier daddy!
Ramblin'_Man's Avatar
Those directions by Jinco are the ones I used... They are very complete. The axle seal tool he made works great too. I had to have a guy at work machine a floor flange to the right diameter to make the axle seal tool though. Otherwise, the only thing you may need are air tools to get the knuckle off. If you are halfway through the project and have problems, ask here before you break any tools because there are a lot of guys on here that have come across a lot different and unique issues doing ball joints. Good luck!
2001 PSD F250
Born 4/01 in KY USA,
4x4, 3.73, Ext. Cab, Shortbox...
ITP RR, CCV, Tymar Intake, Airdog, DP tuner
Ramblin'_Man is offline
post #5 of 5 (permalink) Old 04-19-2008, 05:40 PM
Proud PSN Sponsor
Deputydog's Avatar
Here is the one from TDS..
http://www.thedieselstop.com/content...20Installation
820 HP on 05/19/12
Toll Free 866-379-8685
Deputydog is offline
