CB question! - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 34 (permalink) Old 04-13-2008, 04:17 AM Thread Starter
Custom Trailer Sales
TrailerHauler's Avatar
CB question!
Well I bought my antenna's today to hook up to the CB so I can use it.
I meant to buy 2 antenna's with 2 seperate wires for each antennas. I bought them together and they came with with a wire that goes from both antenna's into one cable, then into the cb. I only want to hook up one of the antennas, because I heard they don't work well together if they're closer than 8 foot. By the way they're going on the mirrors. Even if they are fine closer than that I don't want to bother running the wire for the other antenna. So one antenna will be functional, and the other will be for looks. I don't see any advantages to having more than one antenna anyways.
What I'm asking is, can I cut the wire going to the 2nd antenna and use it as one cable?
Or should I just coil up the wire for the second antenna and put it away somewhere?
If that makes sense...
1999.5 F350 PSD CC Dually 05' Conversion
Stage I's - Gearhead Tuning - BTS - PCS
F550 rear suspension
1999.5 F350 PSD S/C 6spd Dually
R.I.P. Will Iott - "This ain't no practice run"
TrailerHauler is offline
post #2 of 34 (permalink) Old 04-13-2008, 02:17 PM
Bigfoot is an OBS
cowboy_dan's Avatar
Re: CB question!
I don't know about cutting the wires, but If it was me, I'd just coil it up and tuck it away out of site.
I will speak from experience and say that the antennas on the mirrors are NOISY! I might not be so bad for the big rigs with mounts above the top of the window, but on a PSD, the antennas HOWL on the highway. I don't notice the noise until about 40mph.
I'm going to get a single on the roof, or put the duals on the front of the bed.
Go ARMY!
cowboy_dan is offline
post #3 of 34 (permalink) Old 04-13-2008, 02:47 PM Thread Starter
Re: CB question!
alright, I'll see how I like it when I'm done. See how annoying it is, but I think I'm going to just tuck it away for now
post #4 of 34 (permalink) Old 04-13-2008, 05:40 PM
6Leaker
jdc753's Avatar
Send a message via AIM to jdc753
Re: CB question!
As for the wire thing, I would say either just coil up the unused side, or if you feel like buying another wire somewhere get one made for a single antenna.
As for the noise issue I wouldn't say they are noisy, but maybe I am not that sensitive to the noise they make. I don't really start to notice it till about 4-45mph and they don't seem to make all that much more than maybe some slightly aggressive tires around 75-80 and above. Its certainly nothing that would hinder conversation.
2005 F350 Crew Cab Long bed
6.0L / Auto 4x4
SCT X3 5" Magnaflow
4" RCD lift, a bunch of stereo gear and a computer
jdc753 is offline
post #5 of 34 (permalink) Old 04-14-2008, 12:11 AM Thread Starter
Re: CB question!
I put it all together, and just chopped up one side of the wire. I mounted one antenna and used just the end of one side of the wire, after I cut it off, and hooked it up and just dropped it into the door. But that antenna's fake. The other one I hooked up, ran a ground from the mount into the door then through the boot between the door and the truck. I ran it up above and just tuked the extra wire up above the visor and plugged it in.
All I get is static on all the stations? Is it because of my location. I'm not very close to any major highways, I'm about 10 miles from the closest highway (I-69).
Is this normal, or did I do something wrong?
post #6 of 34 (permalink) Old 04-14-2008, 02:22 AM
Don't EFN worry about it
Aljay's Avatar
Re: CB question!
What kind of radio? does it have upper and lower side bands? Is it a 10 meter radio?
Tuned by T Wildman
Aljay is offline
post #7 of 34 (permalink) Old 04-14-2008, 12:20 PM
The Fireman
big_stroker's Avatar
Re: CB question!
did you peck and tune it? i can get 20 miles with mine
big_stroker is offline
post #8 of 34 (permalink) Old 04-14-2008, 05:49 PM
Know nothin' PSD driver
Greg373's Avatar
Re: CB question!
No, you CANNOT just cut the co-ax. Buy a seperate piece the length you need.
[SIGPIC] 2001 F-350 CC SRW 4X4 Lariat;
PMR's
[/CENTER][/SIGPIC]
Greg373 is offline
post #9 of 34 (permalink) Old 04-14-2008, 07:51 PM Thread Starter
Re: CB question!
Well that's probably my problem, I'll just get a piece. Do places like radioshack have it?
I didn't tune it either????
Also my radio is a new Cobra 25LTD
post #10 of 34 (permalink) Old 04-14-2008, 08:36 PM
General Flunky
VC-Racing's Avatar
Re: CB question!
this is a standard length is 18 ft. but i have had good results with a 9ft piece. are your antennas tuneable? or are they the "Firestik" antenna type with the wire wrapped around a fiberglass mast? if so , the antennas are not tuneable. However I'd still have the SWR checked.
01 F-350 CC Lariat SB 4x4: 7.3, TYMAR , AutoMeter Lunar Gauges Boost,Pyro,Trans.,Galaxy 99v ,w/ Wilson 1000,Astatic 636, Optima Redtop,Lund Tonneau.
Malo periculosam libertatem quam quietum servitium. - I prefer liberty with danger, to peace with slavery.
VC-Racing is offline
