2003 door sensor problem - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 04-06-2008, 07:46 PM Thread Starter
<----Simply the best.
StrokerTurbo7.3's Avatar
Send a message via AIM to StrokerTurbo7.3
My dad has a 2003 6oh and he says when he turns the truck off the dome lights stay on for what he says is 30 minutes. When he turns the truck on they stay on until he gets up to 15 mph. Any idea what is making it do this?
I know its not "Aftermarket" its the only thread for SD isnt it?
No longer a proud member of PSN.
StrokerTurbo7.3 is offline
post #2 of 10 (permalink) Old 04-07-2008, 03:36 PM
txpsdcrwchf's Avatar
Send a message via Yahoo to txpsdcrwchf
Re: 2003 door sensor problem
Technical would have been more appropriate but this will do. My truck had the same problem truth is I don't know what fixed it but it stopped when I fixed my door locks! Lol but I've heard people wd 40 the door switches (switch door contacts when closed) and also the bar at the front of door that keeps it from flying open. Hope this helps.....
Jeff
HIS: EARLY '99 F250 SD 4x4 Off Road, 7.3L PSD 6 SPD SuperCab Short Bed
DP Tuned (F5) NS, S, 40T, 80E,
HPx Line-DIY Tymar-Fuel System(on Return)
HERS: '99 DODGE Ram 2500 4x4 5.9l I6 Cummins 6SPD QuadCab Shortbed
Edge ez 20, 40, 60:
txpsdcrwchf is offline
post #3 of 10 (permalink) Old 04-07-2008, 05:39 PM
fbilly420's Avatar
try spraying some WD-40 in the door latch sometimes the door ajar switch will stick. Spray the WD in and open and close the door about a dozen times to get it moving. If that doesnt work pull out the door latch and install new door ajar switch.
Billy
2001 F250, CCSB, 4X4, Auto, Forged rods
Lots of go fast parts and still slow.
2001 F250, STD cab, 2WD
Frame is a little shorter now
workin on body
engine build underway
fbilly420 is offline
post #4 of 10 (permalink) Old 04-07-2008, 07:00 PM
Billy
Jeff
Edge ez 20, 40, 60:
post #5 of 10 (permalink) Old 04-07-2008, 10:09 PM Thread Starter
I tried lol. I'm foreign to the SD threads.
Thanks for the input though I will give it a shot because I know dad wont do it.
post #6 of 10 (permalink) Old 04-08-2008, 03:47 AM
eh it gets the job done right?
Jeff
Edge ez 20, 40, 60:
post #7 of 10 (permalink) Old 04-10-2008, 12:20 PM
BUFF's Avatar
Not to sound like an a$$ but just to make shure. Is the dome light switch turned off on the dash and working properly?
06 F350 CC LB 4x4 with a few odds and ends
BUFF is offline
post #8 of 10 (permalink) Old 04-11-2008, 08:51 AM
iceman89m's Avatar
The switch is intergrated with the strike plate on the inside of the door, I had the same problem after I washed the truck one time, I tried lubing the strike plate up well with Gibbs Lube and it cured the problem..
iceman89m is offline
post #9 of 10 (permalink) Old 04-11-2008, 05:21 PM Thread Starter
I would imagine though the lights wouldnt turn off if the switch was on.
post #10 of 10 (permalink) Old 04-12-2008, 08:17 AM
BUFF's Avatar
It will turn off with the switch on but takes around five min thats why I asked.
BUFF is offline
