Tailgate? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 04-06-2008, 07:05 AM Thread Starter
Tailgate?
I seen a freind today loading his King Quad into 02' F250. When the tailgate cables broke, leaving a big crease across his tailgate. Now I am worried about mine doing the same. Is there any upgrades for the OEM cables?
01' F250 PSD CC 4x4, GTP38R, Hi-Flow outlet, DI Bellowed up-pipes, BTS Hpop, DI Regulated return, ITP Annilator, AM 3pod, AFE PG7 Stage II, Silverline 4in T-Back, 6.0 Trans cooler, Dp F5, BTS Trans, True-Trac 3.73, Powerslot Cryo, Rotella ELC, Nitto Terra 285/75/16E on Alcoa wheels
Torque37 is offline
post #2 of 7 (permalink) Old 04-06-2008, 02:56 PM
All done now
Arisley's Avatar
Re: Tailgate?
Pull off the tailgate when loading a RV in. Set the ramps on the bed, not the tailgate. The tailgate is not designed for that much of a load. It shoule be though.
Arisley is offline
post #3 of 7 (permalink) Old 04-06-2008, 05:42 PM
Re: Tailgate?
What actually broke? Arent those cheesy eyes just crimped on the cable?
1999 F350 6SPD 4x4 LARIAT Tymar, DP-F5, ITP Reg Return, 4" Exhaust **SOLD**
2002 F350 REG CAB DRW 2WD Tymar, PHP, 5" stack, DJM drop hangers and shackles, Hellwig sway bars, Nathan K5LA, Full Power '08 Mirrors...**SOLD**
DIRTBIKEZ is offline
post #4 of 7 (permalink) Old 04-06-2008, 05:56 PM
Custom Trailer Sales
TrailerHauler's Avatar
Re: Tailgate?
I say take an extra minute to just pull off the tailgate, that's what I do with mine when I load up an atv
1999.5 F350 PSD CC Dually 05' Conversion
Stage I's - Gearhead Tuning - BTS - PCS
F550 rear suspension
1999.5 F350 PSD S/C 6spd Dually
R.I.P. Will Iott - "This ain't no practice run"
TrailerHauler is offline
post #5 of 7 (permalink) Old 04-06-2008, 11:14 PM
99 7.3's Avatar
Re: Tailgate?
i just drop the tailgate and load it. the rear of my grizz rides on the tailgate - never had a problem with it
09 6.7 cummins w/ a couple things
99 7.3 is offline
post #6 of 7 (permalink) Old 04-07-2008, 02:46 AM Thread Starter
Re: Tailgate?
The cables have a rubber coating on them, but it appears thay have rusted down inside. They actual broke almost right in the middle.
Torque37 is offline
post #7 of 7 (permalink) Old 04-09-2008, 09:08 PM
bigd4me2's Avatar
Re: Tailgate?
I think they might have had a recall on them at some point and time,but maybe they were just on back order nation wide, i really don't remember which one, gettin old! but as others have said, to load you should remove tailgate if possible.
02 dmax cc dually 4wd "miss piggy" tow bitch, afe pr7, magnaflow, Kennedy lift pump, dual rail mount filters, PPE tunes
00 f350 srw rc=6100lbs
ats comp housing,bdp 1.0 exhaust,afe pr7,4in turbo back magnaflow,hx cross,di regulated return,bbha,dp hi,40,80e,120r,6.oh no cooler autometer gauges, dual rail mount filters
bigd4me2 is offline
