cheap lift ?'s - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 03-19-2008, 08:56 PM Thread Starter
mikek4599's Avatar
cheap lift ?'s
I know, I used the search feature but I just wanted a straight answer.What is the cheapest way to lift my F-350 diesel up 4"? I found some hangers on ebay for cheap but I dont know how good they work.I dont mind if I get a rougher ride since it allready rides like a dump truck and it's not my daily driver.
Thanks
mikek4599 is offline
post #2 of 6 (permalink) Old 03-19-2008, 09:55 PM
Sleep well my brothers
yamt03's Avatar
Re: cheap lift ?'s
Sit on a phone book. J/J'in I thing the hangers will work but I'm not 100% sure.
Early 99 CC DRW AFE, 4" MBRP,Autometer,6.0 trans cooler, ITP, DP Tuner and cupholder upgrade
Former U.S.A. Res. MP & proud of it!
2005 Dodge 4x4 5.9 With some stuff done to it.
"If you voted for Obama in 2008 to prove you're not a racist…you'll have to vote for someone else in 2012 to prove you're not an idiot."
yamt03 is offline
post #3 of 6 (permalink) Old 03-19-2008, 10:16 PM
Go Away I'm Baitin
fishinfool98's Avatar
Send a message via AIM to fishinfool98
Re: cheap lift ?'s
Originally Posted by yamt03 View Post
Sit on a phone book..
you can do the hangers but dont forget to get a
drop pitman
swaybar endbar links
you can do an add a leaf for the rear
(mine rides rough if it doesnt have some weight in it
06 CCLB SRW grey first mod was PSN sticker
Sailors may come
Sailors may go
Tis the engineer below
That makes it Suck, Push, Bang, and Blow
"Closed due to EXPLOSIVE diarrhea, will be back when the EXPLOSIONS are over!"
fishinfool98 is offline
post #4 of 6 (permalink) Old 03-26-2008, 11:32 PM
Re: cheap lift ?'s
Originally Posted by fishinfool98 View Post
you can do the hangers but don't forget to get a
drop pitman
You will also need a track bar drop bracket, possibly a carrier bearing drop kit and new shocks too. For the rear, you will need an add-a-leaf or higher blocks and new ubolts.
LOOSEWHEEL is offline
post #5 of 6 (permalink) Old 03-27-2008, 09:26 PM Thread Starter
mikek4599's Avatar
Re: cheap lift ?'s
Will a 4" lift make my 33's look too small?It allready sits high but if I turn really tight they will rub.
post #6 of 6 (permalink) Old 03-28-2008, 06:35 PM
Sofa King Cool
BMac's Avatar
Send a message via AIM to BMac Send a message via MSN to BMac Send a message via Skype™ to BMac
Re: cheap lift ?'s
I think my 35's look small on a 4" lift
People Fly Airplanes, Pilot's Fly Helicopters
2002 F350 Extended Cab Shortbed
1977 Early Bronco
BMac is offline
