Another random question... - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 16 (permalink) Old 03-14-2008, 11:01 PM Thread Starter
Hoosier daddy!
Ramblin'_Man's Avatar
I put a 4" lift kit on last summer and 35" tires... I'd like to get the truck back to where it used to be in terms of "quickness..." It's not really bad at all with the 35's but it lost a little get-up-and-go... What is involved in changing over to say 4.10 gearing? Do I just buy the new ring and pinion and slap them in or is this one of those "if you change this, you have to change everything" kind of jobs? Also, would it be ok to go to 4.10 or is 4.30 a better choice to get my truck back closer to where it was pre-lift kit? Thanks for letting me pick your brains guys!
2001 PSD F250
Born 4/01 in KY USA,
4x4, 3.73, Ext. Cab, Shortbox...
ITP RR, CCV, Tymar Intake, Airdog, DP tuner
Ramblin'_Man is offline
post #2 of 16 (permalink) Old 03-14-2008, 11:35 PM
Send a message via AIM to JohnT
Re: Another random question...
Not sure on what to use for gearing, but changing gears yourself isnt an easy job. You need to know what your doing and buy install kits to get all the measurements right, or the new gears well prematurely wear out. This is the site I learned alot about redoing the gearing on my truck back to 3.73's.
http://www.differentials.com/install.html
Its not a bad job if you have the right equipment, it took me about 6 hours to do the rear axle for the first time, but the front axle I did not do, since I got an entire axle with 3.73 gears for cheaper than it would have been to change out the gearing(long story). If after reading those instruction you feel you can do it, than go for it, I did and mine has been good for a year and a half now, i checked it last year, everything was still good. 35K later, still going good.
99 PSD 4x4 CCLB
05 PSD 4x2 RCLB
JohnT is offline
post #3 of 16 (permalink) Old 03-15-2008, 03:12 AM
All done now
Arisley's Avatar
If you are interested, bring your truck over, I will swap my 4:10 for your 3:73, and we will learn how to do it together. Ain't nothing but a step at a time. I ain't skeered. Mine is just 2WD though.
Arisley is offline
post #4 of 16 (permalink) Old 03-15-2008, 06:20 AM
00PSD1's Avatar
Why dont you add a DP chip? That would be easier and cheaper then a gear swap and you will have that get up and go you are looking for.
00PSD1 is offline
post #5 of 16 (permalink) Old 03-15-2008, 05:00 PM
OBS junkie
Cat_Rebel's Avatar
With a good chip like a DP Tuner you could keep your 3.73s & still run the 35s. John is running 37s with 3.73 & a DP Tuner. It might not be as good off the line as a truck with 4.10s but it will move just fine once it's rolling.
Or if you still want 4.10s I'll trade you your 3.73s for the 4.10s in my truck. Yes they will fit too.
97 F350 CCLB "Da Bus"
RIP Will Iott
"This ain't no practice run"
Cat_Rebel is offline
post #6 of 16 (permalink) Old 03-15-2008, 05:05 PM
My Detroit Diesel 6v92
dlonno's Avatar
I would'nt go 4.30's with 35's. I went 4.30's with 37's and its just about perfect. Gave me back the giddy up low end power I lost with the lift and tires. If you drive highway a lot, I would keep the 3.73's for mileage.
dlonno is offline
post #7 of 16 (permalink) Old 03-15-2008, 08:53 PM
I don't think he won't be able to use 4x4 unless he changes the front gears too.
npen is offline
post #8 of 16 (permalink) Old 03-15-2008, 10:00 PM
Oooo, White Lightning !
Dieselboy's Avatar
4:30 would be steep for 35's
Matter a fact, 4:10s is to.......just throw a chip on her
I run 37's on 3:73, Ive had the stockers, 35s and 37s on 3:73........the 35s were fine, especialy with the chip
And i would recommend paying someone to do it for you, its finicky and can go wrong in a hurry and end up costing twice as much
Race truck
2002 F-350XL RC/LB
NADP Race Trans/PCS'd
Lowered w/ traction bars
Unlimited 450/400s
S475 on Irates mount
TE 17* with Gen3
DI Headers
Dieselboy fuel system
[email protected]
599.3 on BDs dyno
Tow pig
2000 F-250XLT EC/SB
Tuned
Exhaust
Intake
Dieselboy is offline
post #9 of 16 (permalink) Old 03-16-2008, 06:27 AM
99 PSD 4x4 CCLB
05 PSD 4x2 RCLB
JohnT is offline
post #10 of 16 (permalink) Old 03-16-2008, 09:50 AM Thread Starter
Hoosier daddy!
Thanks for all the replies guys. I am planning on buying a DP tuner soon anyway, so maybe I'll hold off on making gear swaps... I do drive highway a lot too... I was just entertaining the idea after reading an article about how larger tires will throw off your gearing... I guess what I really wanted was to hear all your opinions on making the swap... And thanks for the offers to swap rear ends too...
2001 PSD F250
