URGENT-Parking brake and clutch pedal problems - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 12 (permalink) Old 03-10-2008, 04:14 PM Thread Starter
thetonka's Avatar
My parking brake broke the other day. I have had this happen before and replaced the broken cable. This time it appears to have broke inside the pedal assembly. I need to take it out and look, but didn't have the time last weekend. If it needs to be replace where would be a good source for something like this?
Also my clutch pedal is really worn out and wobbles around ALOT. The bushing holes in the aluminum part where the the pedal pivots are REALLY worn out. I am actually a bit worried. So where could I get that part.
I am currently having to drive the truck since I had to order a tire for my motorcycle. Doing a lot of clutchless shifts, and parking on flat ground. Quick help would be greatly appreciated.
Thanks
2001 F350 CC LB 4X4
TN, AIS, DP 80hp, ITP boost elim, Magnaflow 4".
Tows the big white hauler.
When life gives you Lemons, throw them at the stupid people.
thetonka is offline
post #2 of 12 (permalink) Old 03-10-2008, 04:37 PM
All done now
Arisley's Avatar
Re: URGENT-Parking brake and clutch pedal problems
I think I would check with www.powerstrokeshop.com for both issues.
Arisley is offline
post #3 of 12 (permalink) Old 03-10-2008, 04:47 PM Thread Starter
thetonka's Avatar
I'll have to check them tonight, my work blocks their site as an advertisement.
2001 F350 CC LB 4X4
thetonka is offline
post #4 of 12 (permalink) Old 03-10-2008, 04:59 PM
All done now
Arisley's Avatar
If you can't find the part you need on line call them they will take good care of you.
Arisley is offline
post #5 of 12 (permalink) Old 03-10-2008, 05:44 PM
jshank's Avatar
1-800-572-1422
just in case you want to call before you get home
2003 f250 crew traded for higher education
new ride 2004 wrx wagon
jshank is offline
post #6 of 12 (permalink) Old 03-10-2008, 07:04 PM Thread Starter
thetonka's Avatar
I'll try and call in a little while. Gotta run to tour a controlled access area.
2001 F350 CC LB 4X4
thetonka is offline
post #7 of 12 (permalink) Old 03-11-2008, 02:57 AM Thread Starter
thetonka's Avatar
OK didn't get to call but checked the website. They have nothing on clutch pedal, but they have a listing for a parking brake control. ????? Is that the parking brake pedal assembly???
Also found a recall on parking brakes but its for MY 1999. Anyone know where I can find out more info?
Anywhere else I can look for a clutch pedal? Am I going to have to make one???
2001 F350 CC LB 4X4
thetonka is offline
post #8 of 12 (permalink) Old 03-11-2008, 03:03 AM
All done now
Arisley's Avatar
I bet if you call them, they have one.
Arisley is offline
post #9 of 12 (permalink) Old 03-11-2008, 03:20 AM
Evil Genius
DCSpecial's Avatar
So the parking brake assembly broke or the cable broke?
DCSpecial is offline
post #10 of 12 (permalink) Old 03-11-2008, 04:32 AM
Proudly Serving The USA
cvdenson's Avatar
My parking brake assembly broke and I ordered mine from powerstrokeshop.com. I replaced it this past weekend and works fine. All the years are the same.
Chris
Chris
Early 99 F350 XLT 4x2 CC LB SRW 6sp
modded 17 HPOP, CCV, 203 T, SS HPX, ITP OBA, Oilguard, Hutch/Harpoon, Ford AIS/zoodad, ITP RR, 08 Differential Cover, Autometer Pyro/Boost, 4" MKO straight-piped, DieselSite Coolant Filter Kit, DP F5 (stock, no start, high idle, 80e), TurboMaster WG, DPP Boots, Aerotank 55 gallon midship tank.
cvdenson is offline
