Anything out there to keep the sludge out?? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 8 (permalink) Old 03-10-2008, 02:46 PM Thread Starter
JDG's #1 Fan
99F250Smitty's Avatar
Send a message via AIM to 99F250Smitty
I am tired of cleaning, mud, snow/salt, etc from along the bottom edge of my doors. It is also causing RUST!! It gets up inbetween the doors and the cab and makes a mess. I have mud flaps, but doesn't seem to matter. i was wondering if there is anything on the market or if anyone has made their own kind of bent steel to keep all this crap out.
Brian
_____________________________________________
99.5 F250 Extended Cab Short box. 4x4.
99F250Smitty is offline
post #2 of 8 (permalink) Old 03-12-2008, 04:38 AM
Re: Anything out there to keep the sludge out??
I run the stock plastic running boards, and they keep anything from getting up under the doors. I had them off for a while and put them right back on due to the same problem you have
npen is offline
post #3 of 8 (permalink) Old 03-12-2008, 12:06 PM Thread Starter
JDG's #1 Fan
its a mess, you get into mud, its packed up in there, you drive on slushy roads, its packed up in there. I think the newer trucks have a rubber piece acrossed the bottom of the door, but it still gets up in there behind it. I looked at an 04 that had rust along the bottom of the door.
Brian
post #4 of 8 (permalink) Old 03-13-2008, 05:05 AM
DarkShadowDiesel's Avatar
i actually have to have part of the lower front doors cut out on my 02. the sh!t got up in the door and the door seam weld rusted, and now some of the inside of the door is actually completely rusted. i think the best you can do is a set of mud flaps and clean it out well. i can tell you my #### is a mess, i actually put a screwdriver through the door knocking some of it off not realizing the entire piece was rusted.
2002 F250
DarkShadowDiesel is offline
post #5 of 8 (permalink) Old 03-13-2008, 11:25 AM Thread Starter
JDG's #1 Fan
Yeah, my front doors aren't terrible yet, but i imagine if i pushed on my extended cab doors to hard i could put my finger through.
Brian
post #6 of 8 (permalink) Old 03-14-2008, 05:56 AM
i think i might have that part of the door rhino lined once it's fixed.
2002 F250
post #7 of 8 (permalink) Old 03-19-2008, 09:11 PM
Custom Trailer Sales
TrailerHauler's Avatar
I have stock running boards and don't have much of a problem. The bottom of my front doors is rusting a little bit, probably from what your talking about but not very badly at all!
1999.5 F350 PSD CC Dually 05' Conversion
Stage I's - Gearhead Tuning - BTS - PCS
F550 rear suspension
1999.5 F350 PSD S/C 6spd Dually
R.I.P. Will Iott - "This ain't no practice run"
TrailerHauler is offline
post #8 of 8 (permalink) Old 03-23-2008, 04:31 PM
jeromejcp's Avatar
I just had to POR15 the bottom of my doors, they were really bad, if I didn't do it now by mid summer I would have been looking at having to add more metal... I removed the rubber strips down there, the clips were gone on them anyways. It doesn't make the truck any noisier with them gone. I think just washing the crap out of there every once in a while with good paint and possible bed liner covering (linex rhino liner, POR15 bed liner...) is going to be the only thing you can do. Running boards don't help, I got the stock plastic ones and I still have rust. BTW I am removing them because they did nothing when someone hit and ran my truck when it was parked.
Good luck
Jeremy
00 F350 CC LB 4x4 auto. Nitto Terra 285 75 r16 E, Dynatrac free spin hubs, ccv, rancho stabilizer, centramatics, upgraded GPR, DB starter, 2.0 ga pos cable, matching 5th rim, 6637, 4" SS magnaflow, CPR, Scan Gauge, Mag Hytech.
USN VBSS, Burn sink or take a-prize.
jeromejcp is offline
