Blend door problems, not vacuum pump. - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 03-08-2008, 09:24 PM Thread Starter
Engineering College Boy
Got Diesel's Avatar
Send a message via AIM to Got Diesel Send a message via MSN to Got Diesel
Alright fella's got a problem with the blend door on my truck. It's in default defrost only mode. Vacuum pump is good have vacuum under the dash. Don't know what to check next. Any advice is appreciated. Thanks Kyle.
Kyle
Early 99 F-250SD 7.3 PSD 4x4. Auto, tymar type intake, straight pipe, Six inch stacks, Tony Wildman Four position chip, Street race, 80 Tow, 80 Econo, Extreme. Let the smoke roll. Upgraded torque converter. Autometer Ultralights on the Pillar. Running Cooper Discover STT's.
SLAPS MEMBER
Got Diesel is offline
post #2 of 4 (permalink) Old 03-08-2008, 09:45 PM
All done now
Arisley's Avatar
Re: Blend door problems, not vacuum pump.
Check door linkage.
Arisley is offline
post #3 of 4 (permalink) Old 03-14-2008, 02:00 AM
Above It All
Cool Canuck's Avatar
The blend door is electric and has nothing to do with defrost. Only hot and cold.
There is a vacuum actuator at the bottom of the HVAC unit that does one of the direction things. Not sure if it's defrost or not. You can see it do it's thing just by getting down there. Check the vacuum lines under by the passenger foot well. I can't imagine it being the switch, but it can be got at by pulling the radio and dash. Not a bad job.
'01 F250 SC/SB 4X4 Trailer Tug
Cool Canuck is offline
post #4 of 4 (permalink) Old 03-14-2008, 04:48 AM
ARMY bound
make sure you have plenty of vacume on the black hose behind the temp controller.
bbbxcursion is offline
