Tranny temp gauges doesn`t work! - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 02-29-2008, 01:36 PM Thread Starter
ASTRO's Avatar
My tranny temp gauge has been installed on my truck since fall of 2002, it move alittle at first it would go just a little past 100 degrees. But after that (less than a year) it just stop moving all together. I did chech and it seams to be connected right at the gauge inside the truck. i also took the sender unit out of the tranny and it did have fluid on it and fluid did weep out. I cleaneed the sender threads and reinstalled it. still no movement. Waht do you all think? Just go buy a new one or what? Thanks for any and all input!!
MY 2002 f250 4x4 larait crew cab short bed. 12.5" Icon lift w/ OneUpOffroad 5" traction bar block system. Mickey thompso 38X15.50R18 tires on Weld Dune 8 18x10 wheels. Custom pearl silver &purple flame paint, MBRP 4" T-304 SS cool dual exhaust w/ custom made T-304SS flame tips, AFE stage 2intake. Way More!
ASTRO is offline
post #2 of 7 (permalink) Old 02-29-2008, 02:00 PM
Sleep well my brothers
yamt03's Avatar
Re: Tranny temp gauges doesn`t work!
If the sender is tapered and you put tape on the threads that might be it.
Early 99 CC DRW AFE, 4" MBRP,Autometer,6.0 trans cooler, ITP, DP Tuner and cupholder upgrade
Former U.S.A. Res. MP & proud of it!
2005 Dodge 4x4 5.9 With some stuff done to it.
"If you voted for Obama in 2008 to prove you're not a racist…you'll have to vote for someone else in 2012 to prove you're not an idiot."
yamt03 is offline
post #3 of 7 (permalink) Old 02-29-2008, 03:29 PM Thread Starter
ASTRO's Avatar
I pulled the sendr out and it`s tapered , but I took a wire brush and cleaned the treads and reinstalled it without any tape.
ASTRO is offline
post #4 of 7 (permalink) Old 02-29-2008, 04:15 PM
Oooo, White Lightning !
Dieselboy's Avatar
Buy a new one
Race truck
2002 F-350XL RC/LB
NADP Race Trans/PCS'd
Lowered w/ traction bars
Unlimited 450/400s
S475 on Irates mount
TE 17* with Gen3
DI Headers
Dieselboy fuel system
[email protected]
599.3 on BDs dyno
Tow pig
2000 F-250XLT EC/SB
Tuned
Exhaust
Intake
Dieselboy is offline
post #5 of 7 (permalink) Old 02-29-2008, 05:29 PM
<<< THE GAUGE WHORE...
CSIPSD's Avatar
What kind of gauge is it? Does it have a two wire connection or a one wire connection?
Joe
CSIPSD is offline
post #6 of 7 (permalink) Old 02-29-2008, 07:57 PM Thread Starter
ASTRO's Avatar
One wire .
ASTRO is offline
post #7 of 7 (permalink) Old 02-29-2008, 07:58 PM Thread Starter
ASTRO's Avatar
It`s an autometer Z series tranny temp gauge. sorry! The unit light up when the light are turned on , but never moves on the temp.Bottomed out below 100 degrees.
ASTRO is offline
