what 3 guages? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 12 (permalink) Old 08-22-2010, 04:20 PM Thread Starter
Waitin' on 500
Choupique108's Avatar
what 3 guages?
Im wanting to do the 650 manual lower dash piece and im wanting to add another 2 or 3 gauges in it.
I have boost, trans, pyro, and air psi for my horns on the pillar already.
What would be 3 very handy gauges to have?
Im thinking:
oil temp, Fuel Pres, HPOP
or
Oil Temp, Fuel Pres, Scan gauge
Give me your opinions.
Thanks.
1997
Single Cab Dually
S366 w/Irate mount and plenums, EFuel, Intercooler, P.I.S 175/80s,
Corbeau seats w 08 console, 19.5s, Black Interior with swede headliner and visors,
Custom badges, Flight Fab/DIY traction bars.
2012 CCSB F250 Ultimate Lariat.
Choupique108 is offline
post #2 of 12 (permalink) Old 08-22-2010, 04:22 PM
Super Hauler!
Super_Hauler's Avatar
Re: what 3 guages?
oil temp, fuel,oil pressure. 3 most important after what you already have.
Super_Hauler is offline
post #3 of 12 (permalink) Old 08-22-2010, 04:26 PM
Re: what 3 guages?
Scan gauge can display oil temp and anything else the pcm views. you can add on other sensors for fuel psi.
02 f250
countryboyrob is offline
post #4 of 12 (permalink) Old 08-22-2010, 06:53 PM
Wondering what if
123rday68's Avatar
Re: what 3 guages?
With the 7.3, is it the same as a 6.0 as far as the 15 degree difference between eot and ect? If so, oil temp, coolant temp, and fuel pressure.
Try Kenny at KEM Performance (vender on here for pricing).
'07 F350 3" lvl, fndrs trmd, 37" M16's
Ultra lites ECT,EGT,EOT Oil and top fuel billet caps
banjo bolts drilled cautiously, ccv, zoodad mods Dieselsite coolant filter
SCT SF3 can tunes
Mike's Diesel Performance
KT Performance
DieselPowerProducts.com
Dieselsite
123rday68 is offline
post #5 of 12 (permalink) Old 08-22-2010, 07:09 PM Thread Starter
Waitin' on 500
Re: what 3 guages?
I really like the scan gauge bc of what all it does. If i get the scan gauge, ill add it to my pillar pod and move the air psi down to the 650 dash.
1997
Single Cab Dually
post #6 of 12 (permalink) Old 08-23-2010, 02:37 AM Thread Starter
Waitin' on 500
Re: what 3 guages?
bump.
Anyone else?
1997
Single Cab Dually
post #7 of 12 (permalink) Old 08-26-2010, 03:02 AM Thread Starter
Waitin' on 500
Re: what 3 guages?
anyone else?
1997
Single Cab Dually
post #8 of 12 (permalink) Old 08-26-2010, 06:05 PM
<<< THE GAUGE WHORE...
CSIPSD's Avatar
Re: what 3 guages?
If you go with a scan gauge then go scan gauge, water temp and fuel pressure...
The PCM can not see fuel pressure or water temp so...
Without the scan gauge I would go oil temp, water temp and fuel pressure.
oil pressure is another one the factory PCM can not see, so you can think of that one as well...
The HPO gauge is a neat toy, but day to day, not needed.
Joe
CSIPSD is offline
post #9 of 12 (permalink) Old 08-26-2010, 10:35 PM
The Original
BigStroker's Avatar
Re: what 3 guages?
Scan gauge as one HANDS DOWN. You will LOVE it. They have so many functions it def makes it a worthwhile gauge.
[CENTER]1994 F350 4x4 5spd, 1995 F250 4x4 5spd, 1996 F250 4x2 auto, 1997 F350 4x4 auto, 1997 F250 4x2 auto
#27
BigStroker is offline
post #10 of 12 (permalink) Old 08-26-2010, 10:42 PM
The Oracle
BigRed97's Avatar
Send a message via AIM to BigRed97
Re: what 3 guages?
i did oil temp, fuel press and hpop.
looking at it now i should have moved my trans temp from the pillar to the 650 piece and put the hpop on the pillar
CCLB with some stuff done .....
BigRed97 is offline
