Smoked cab/tail lights - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 14 (permalink) Old 08-20-2010, 03:13 AM Thread Starter
02 CCSB
I'm looking to get a set of smoked cab/tail light lenses for my '02 and wanted to know if anyone had pics of them installed. Been looking at the Recons. Thanks in advance.
02 CCSB Lariat F-250, Auto, 3.73, 6", 35" Toyo OC MT, Juice w/Attitude, 4" Turbo back MBRP, owner built trans, billet triple disc, 31 row 6.0 cooler, tugger and aux filter, Snow tow max
94 RCLB XLT F-150, 5.0 5spd, 4.10 Tru Trac, 4", 33" BFG AT
02 CCSB is offline
post #2 of 14 (permalink) Old 08-21-2010, 01:42 AM
Moved in
sagebel's Avatar
Re: Smoked cab/tail lights
These are DIY using VHT Nightshade.
2011 F250 CC 4x4 Sterling Gray Metallic
2010 Cannondale Quick 4 (pedal powered commuter)
sagebel is offline
post #3 of 14 (permalink) Old 08-21-2010, 01:53 AM
wheres the fat chicks?
PowerstrokeR00's Avatar
i like the looks of that.can you give me a link to where you bought the nightshades?
A right-up of how you did em would be awsome too.
2000 F-350 SD ccsb=185hp
Matt's Tunes=140hp
6637=20hp
2% window tint=25hp
4in straight pipe=50hp
Custom Fuel system w/ sump=50hp
Foil,AIH,EBPV delete=30hp
Wow...I'm making 500hp
Originally Posted by stroke of luck View Post
i started sharting at an early age...
PowerstrokeR00 is offline
post #4 of 14 (permalink) Old 08-21-2010, 02:14 AM
6Leaker
jdc753's Avatar
Send a message via AIM to jdc753
recon LED smoked lights, my only complaint with them is that they didn't come with any sort of hardware to mount them to the cab. Factory ones have studs and is a 1 man job, recons you gotta buy something to do it, and this makes it a 2-man job unless you wanted to epoxy or glue whatever bolt you buy to the light base itself and them tighten them down.
They have been on for over a year though with no troubles and I think look great, plenty bright at night too.
2005 F350 Crew Cab Long bed
6.0L / Auto 4x4
SCT X3 5" Magnaflow
4" RCD lift, a bunch of stereo gear and a computer
jdc753 is offline
post #5 of 14 (permalink) Old 08-21-2010, 02:43 AM
cshsrh's Avatar
They are very bright with thos 6 led wedge bulbs.......Great product so far for me over a year and a half now......
cshsrh is offline
post #6 of 14 (permalink) Old 08-21-2010, 03:22 AM
Moved in
sagebel's Avatar
I got Nightshades at NAPA. Lightly scuffed the lenses with a red 3M pad. Clean. Two light coats. Wet sand with 2000 grit. Clean. 4 coats of clear. Buff and wax.
sagebel is offline
post #7 of 14 (permalink) Old 08-21-2010, 03:26 AM
do you coat the inside or outside of them
Matt's Tunes=140hp
6637=20hp
2% window tint=25hp
post #8 of 14 (permalink) Old 08-21-2010, 03:52 AM
Moved in
sagebel's Avatar
Outside.
sagebel is offline
post #9 of 14 (permalink) Old 08-22-2010, 02:48 PM Thread Starter
02 CCSB
Thanks for the pics, both look great. Sagebel-what kind of clear did you use? Rattle can, what brand, has it peeled/discolored? Thanks in advance.
02 CCSB is offline
post #10 of 14 (permalink) Old 08-22-2010, 03:20 PM
Moved in
sagebel's Avatar
Rattlecan. Duplicolor. Hasn't pealed yet but it's only been on for a week.
sagebel is offline
