power window and radio issue - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 9 (permalink) Old 08-06-2010, 03:18 AM Thread Starter
Hey all,
Just finsihed up a cummins conversion in my truck and when i finally powered everything up today i noticed that my power windows and my stereo deck wouldnt work..they both worked fine a few months ago..its weird cuz the power mirros and the door locks both work..any thoughts?
thanks guys!
Mofugra is offline
post #2 of 9 (permalink) Old 08-06-2010, 03:23 AM
Boomer
7.3SuperDuty's Avatar
Re: power window and radio issue
did you go through all the fuses
2000 Red Ext. Cab 4x4-SOLD
7.3SuperDuty is offline
post #3 of 9 (permalink) Old 08-06-2010, 03:37 AM Thread Starter
Yup, I'm pretty sure i checked them all..ill double check tho..i was reading about some GEMS thing? Sorry I'm new to Ford.
2003 F-250 12V Cummins
Mofugra is offline
post #4 of 9 (permalink) Old 08-06-2010, 03:45 AM
Check the fuses again, the radio and windows and dome light are all on the same fuse, I want to say it is like #42 or 43 but I could be way off. I know when my radio and windows went out I checked 3 times before I found the fuse. Mine blew out when I pulled the dome light to fish my XM radio antenna wire. If you don't find it post back and I'll look it up.
2002 F 350 4x4 CREW 164K, Isspro boost, tranny, pyro, FP, Hpo, coolant filter, Dieselsite tranny filter, AIS intake, ITP pre pump mod, 6.0 tranny cooler, AE & Torque Pro.
bigb is offline
post #5 of 9 (permalink) Old 08-06-2010, 02:55 PM Thread Starter
Well today before I left for work I went and looked at the truck, I turned it on and the radio and windows both worked. Can a bad fuse work intermitently? Or is this a wiring issue that is causing a short. Either way it's odd
Mofugra is offline
post #6 of 9 (permalink) Old 08-06-2010, 05:52 PM
Boomer
what happen to me with my ww is same thing checked fuse it was good, what happenened was onl the tip was making contact, so that might be something to look for
post #7 of 9 (permalink) Old 08-07-2010, 02:04 AM Thread Starter
Ok just double checked and all fuses are good but still no windows or stereo. The wiring going into the back of the fuse panel looks good and those wires have power so I'm not sure what gives.
Mofugra is offline
post #8 of 9 (permalink) Old 08-08-2010, 06:28 PM
Jack Ken
Is it an aftermarket radio? My ex does that sometimes and I smack the dash above the radio and it starts working. I do have an aftermarket radio. Just my $.02
2003 Exursion 7.3 diesel exhaust, intake, ts chip, banks exhaust housing, big head actuator all sittin on 20s w/ 35s.
1989 F350 460 propane, 4inch lift 39.5s
1988 bronco ii 2.3 turbo motor on propane
fordman2121 is offline
post #9 of 9 (permalink) Old 08-09-2010, 04:03 AM Thread Starter
well pulled out the fuse panel started checking wires and the light blue/black wire behind the big 30amp maxi fuse wasnt getting any power..not sure why...but as a temp solution i jumped another wire onto it and voila the windows and the stereo work..now i just need to find out why that wire doesnt have power...
Mofugra is offline
