How in the "heck" do you remove the front turn signal lenses? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 08-06-2010, 12:48 AM Thread Starter
<--501cc,should b 540 : /
'99 stroker's Avatar
Ive searched google and PSN and cant find anything, ive got the 2 screw along the bottom out and the snap thing on the out side, but something is still holding them in, please let me know whats up
'99 stroker is offline
post #2 of 7 (permalink) Old 08-06-2010, 12:51 AM
Extended Power's Avatar
Re: How in the "heck" do you remove the front turn signal lenses?
The bulbs????
After the 2 screws, they just pull out...
2003 F-350 KingRanch 4x4
Extended Power is offline
post #3 of 7 (permalink) Old 08-06-2010, 12:58 AM
Keep er shinny side up!
Originally Posted by Extended Power View Post
The bulbs????
Thats what I thought to, I wonder if its feels stuck due to some road grime in there somewhere?
you ain't earnin' if you ain't turnin'
abbottfarms is offline
post #4 of 7 (permalink) Old 08-06-2010, 01:00 AM
<--before leveler & block
stroker2's Avatar
might try a pry bar.
2000 7.3 F-250 4x4 CC/SB Lariat 6-speed, 2.5" leveler and F350 block, Swamps 200/30% injectors, Swamps tunes, GTP-38R, Valair: kevlar/ceramic clutch, 4inch exhaust, AFE stage 2,
DFA-regulated return, pre-pump mods, Isspro boost and pyro, scan gauge, ~420hp and 836tq
stroker2 is offline
post #5 of 7 (permalink) Old 08-06-2010, 01:17 AM
Bryrylan's Avatar
there is 2 screws and then two pins that clip into place just give it a good pull it will come out.
2002 F-250
Kw w900B with a smaller stack than most pick ups
Originally Posted by yogi7615 View Post
look the word dodge up in any dictionary. it means "to avoid."
Bryrylan is offline
post #6 of 7 (permalink) Old 08-06-2010, 03:28 AM
Need a ride.
Strokerstooge's Avatar
Trying to replace a bulb?? I just took out the two screws and pulled out enough to remove and slip in the new bulb. It was a while ago though..
03 F-250 7.3 XLT CC SB Auto 38R, S-B Intake, 4 inch MBRP Duals, Regulated Return, J Wood VB, DP Tuner, Isspros 3 Pillar, Terminator Scan Gauge, DS Coolant Filter, HPX
Strokerstooge is offline
post #7 of 7 (permalink) Old 08-06-2010, 03:55 AM Thread Starter
Yeah replacing bulbs, someone before me did clear lenses but then proceded to put clear bulbs in them so i was going for the legal thing. You guys were exactly right on those, thanks! the clips toward the center of the vehicle were both very stubborn, but stroker2 somehow managed to get them out.
