water in the stack.. - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 17 (permalink) Old 08-04-2010, 11:40 PM Thread Starter
Sponsor w/out Blue name
powerstrokin15's Avatar
so i just recently put a 7" stack in my truck.. i know it may sound stupid but how can i make it so that after it rains i dont get my truck covered in black water/soot? like a cover, or drain hole, or a 5 gallon bucket like ive been using
HOLDERDOWN PERFORMANCE-Senior Salesman
'09 CC/SB FX4 6.4L
GearHead, IDP, KEM
powerstrokin15 is offline
post #2 of 17 (permalink) Old 08-04-2010, 11:41 PM
KEM Sales & Support
Re: water in the stack..
flapper like on a tractor?
patrickke is offline
post #3 of 17 (permalink) Old 08-04-2010, 11:46 PM
Bucket will work best. But that will get old after a while.
02 f250
countryboyrob is offline
post #4 of 17 (permalink) Old 08-04-2010, 11:48 PM
Still learning
bad moose's Avatar
Drill a hole at the lowest point.
Let's see if I can explain the other option. It's kind of like a bell. I would do it at an elbow towards the rear of the cab. Use a 5" elbow to y pipe. from the turbo back use 4" and slide it in the center of the 5" elbow. The idea is from Charles. Do a search on it if you don't understand.
Not being mean, I just know the explanation is vague.
03 F250 King Ranch
SCT tuned by Eric @ Innovative, Exhaust, and Air Raid filter
EGR Deleted
Still to slow
bad moose is offline
post #5 of 17 (permalink) Old 08-04-2010, 11:49 PM
bulletproof7.3's Avatar
tiny hole in the bottom or your elbow or 90 works good. small enough where you wont leak much exhaust
2000 f250 , 7.3 built trans, K&N intake, warn lock outs, Tonywildman , 4" down pipe to 5" silverline exhaust, ported compressor housing, 07 hd headlights,trans temp, boost, and egt gauges .
bulletproof7.3 is offline
post #6 of 17 (permalink) Old 08-05-2010, 12:27 AM Thread Starter
yea.. thats what i was thinkin on a hole.. i just dont want it to sound like an exhaust leak or have the whole get bigger in age.. and no to the flapper its a mitre
'09 CC/SB FX4 6.4L
GearHead, IDP, KEM
post #7 of 17 (permalink) Old 08-05-2010, 12:29 AM Thread Starter
and bad moose, when i went up with my 4" 90 i went into 5" without using a adapter i bent the 4" to get wide enough to tack weld it.. idk if thats what you meant but in a different place
'09 CC/SB FX4 6.4L
GearHead, IDP, KEM
post #8 of 17 (permalink) Old 08-05-2010, 12:31 AM
07_powerstroke's Avatar
I put a stack on and i drilled small hole i cant remember what size but it works great no exhaust noise....
07_powerstroke is offline
post #9 of 17 (permalink) Old 08-05-2010, 12:35 AM
KEM Sales & Support
could you set something up with a valve and just when it rains open it up
post #10 of 17 (permalink) Old 08-05-2010, 12:36 AM Thread Starter
alright i might try it
'09 CC/SB FX4 6.4L
GearHead, IDP, KEM
