Exterior Door Trim Removal - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 08-04-2010, 03:05 PM Thread Starter
Not long...sure is skinny
Cok_Diesel's Avatar
Hi guys.
The exterior rubber door trim strips on my PDS are peeling up at the ends. I've been thinking of just pulling them off. Has anyone done that and if so how does it look? What should I use to clean up the adhesive that will most likely be left behind?
Thanks.
2000 Ford F-250
Supercab PSD 4x4
6-Speed 8FT Lariat
AEM Brute Force
4" TB MBRP
Bully Dog 4 Bank Chip (TW Tuned)
Originally Posted by Pocket View Post
...it's dripping off my CAC tube.
Cok_Diesel is offline
post #2 of 4 (permalink) Old 08-04-2010, 03:20 PM
C&C Customs
Cory_S's Avatar
Re: Exterior Door Trim Removal
i did it and used goo gone to take offthe sticky stuff the came behind it with rubbing compound
before
after
stage 11 tranny by Doug @GoGo
And a lot of other goods
_____CORY
Cory_S is offline
post #3 of 4 (permalink) Old 08-04-2010, 04:12 PM
Reloading
Critical's Avatar
Try doing it in the mid day sun and use a blow dryer to warm things up as you remove it. I removed one section just by randomly pulling it off and it left behind quite a bit of adhesive behind. The next day I waited till lateer in the day when it was hot and used the blow dryer, that time it left hadly any adhesive behind. I used turtle wax bug and tar remover, but what ever you use test it in a small unseen spot first.
America Land of the free.*
*Some restrictions may apply, void where prohibited.
Critical is offline
post #4 of 4 (permalink) Old 08-04-2010, 04:26 PM Thread Starter
Cok_Diesel's Avatar
Your truck looks a hell of a lot cleaner without them. This weekend is supposed to be wicked hot here so i'll wait till then.
Was there a difference in the paint that was under them (a shadow)?
2000 Ford F-250
Supercab PSD 4x4
6-Speed 8FT Lariat
AEM Brute Force
4" TB MBRP
