Rotor direction? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 08-04-2010, 01:15 PM Thread Starter
Send a message via AIM to Barnbuilder
Rotor direction?
Which way should the vanes on the front rotors face? Should they scoop the air in towards the center? Or sling the heat out as they turn?
1999 F350 CC XLT 4x4 6spd
2006 F350 CC KR 4x4
Barnbuilder is offline
post #2 of 7 (permalink) Old 08-04-2010, 01:22 PM
owner/president
dixieland-diesels's Avatar
Send a message via MSN to dixieland-diesels
Re: Rotor direction?
The end of the slot on the outter edge of rotor should be facing away from the front of the truck at a 12 o'clock position.So i guess that would be slinging.I hope that makes since.
03 lariat cc,4x4 7.3,DP-F5,36''MT,8"lift w/trac.bars,4"Silverline ss.exh,AFE II,Optimas,ATS housing,WW,Turbomaster,6.0 IC & tranny cooler,BTS,ISSPRO gauges,HPX,ITP RR,BRV+,Powerslots,WARN prem-hubs,coolant filter,ccv mod,08 mirrors,ARP's,mod.fuel & inj's.,Crower rods,AIH delete,AMSOIL fluids. ~waitn on the 38R~
dixieland-diesels is offline
post #3 of 7 (permalink) Old 08-04-2010, 01:27 PM Thread Starter
Yes, thanks Dixie. Their on backwards.
2006 F350 CC KR 4x4
post #4 of 7 (permalink) Old 08-05-2010, 04:11 PM
F-25000's Avatar
sorry to steal your thread here but i was tying to take my rear rotors off on my 04 with srw and i could not get them off. do you have to take the hub off to take the rear rotors off on a srw?
2004 F-250 regular cab long box, 6.0 w/ 6 speed, 4" turbo back exhaust, airaid airfilter, SCT, Sinister coolant filter, ARP studs, EGR delete, gauges- sold
2010 F-350 crew cab short bed Lariat. 6.4l with auto trans. Deleted and tuned.
Dylan
F-25000 is offline
post #5 of 7 (permalink) Old 08-05-2010, 05:25 PM Thread Starter
Had the same problem first I removed my rears. I tapped on the "hat" section with a hammer as I applied leverage on the rear of the rotor. Also spray it with some penetrant.
2006 F350 CC KR 4x4
post #6 of 7 (permalink) Old 08-05-2010, 05:35 PM
mbahr22250's Avatar
No. I actually had to heat mine up along the edge of the shoulder and then hit it with a hammer in the same spot to get them off.
'06 F-250 SuperCab 4x4 SRW
Magnaflow Series Turbo Back
SCT X3 - Truck Source Diesel Tune
You can call me Matt.
Originally Posted by JLDickmon View Post
you may win but you're still retarded?
mbahr22250 is offline
post #7 of 7 (permalink) Old 08-05-2010, 07:19 PM
F-25000's Avatar
ya i hit the hat on mine with a hammer. used brake clean and penetrating oil and could not get them off. they were really suck on there. i guess ill have to try heating them up. thanks guys
Dylan
F-25000 is offline
