utility body ease? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 07-27-2010, 11:43 PM Thread Starter
Still a kid to some ppl
oldfordisbetter's Avatar
utility body ease?
work truck lists for way less then reg trucks round me. as in utility bodys instead of pickup beds. how hard would it be to remove the utility bed n bolt on a regular bed? what would i look at to pay for a bed? could buy a 2001 f350 reg cab 4wd with an utility bed white with 199000 for $3800 but for same truck with a bed they're going for 7-12g round here...
oldfordisbetter is offline
post #2 of 7 (permalink) Old 07-29-2010, 08:02 PM
F350 Balla
Send a message via AIM to 4eyedconekiller
Re: utility body ease?
I dont know this for sure, but I would figure that most utility bodies would be a bolt-on affair. I would also ASSume that the frame rails would retain the mounts for the factory bed. Depending on condition, your're looking at 1000-1500+ for a bed. Make sure that you get bed bolts, taillights, etc. for your conversion.
If you dont mind the work, and everything just bolts together, I don't think its a bad idea, other than most work trucks - unless records show otherwise - are usually not taken care of in the greatest fashion. Just make a good point of checking the truck out fine, and you should be in good shape.
-Michael
'99 F350
-DIY aFe Big Boost, MBRP 4",DI Tunes, ISSPROs, Sonnax/Tri, HD Headlights/5000k HIDs, Tinted tails, Painted XL Grille, Moulding/multiple emblem delete
-Tunes by Alpine, Boston Acoustics, Memphis Audo, and Audiobahn.
Look for drop, 22's, bedcover and wrapping up the dechrome
4eyedconekiller is offline
post #3 of 7 (permalink) Old 07-30-2010, 11:22 PM
BUFF's Avatar
You need to check the frame. If it was built as a cab-chassie the rails will be flat and a standared bed wont fit. But if it originaly had a bed on it the frame curves over the rear you can swap back.
06 F350 CC LB 4x4 with a few odds and ends
BUFF is offline
post #4 of 7 (permalink) Old 07-31-2010, 01:12 AM Thread Starter
it was flat so no good. my dad is a 30yr diesel mechanic so he looks at anything i would buy..
post #5 of 7 (permalink) Old 08-01-2010, 02:42 AM
BUFF's Avatar
You could always put a flatbed on it.
BUFF is offline
post #6 of 7 (permalink) Old 08-02-2010, 12:34 AM Thread Starter
na flatbeds look gay
post #7 of 7 (permalink) Old 08-02-2010, 04:18 PM
Bryrylan's Avatar
I must of missed that memo.
2002 F-250
Kw w900B with a smaller stack than most pick ups
Originally Posted by yogi7615 View Post
look the word dodge up in any dictionary. it means "to avoid."
Bryrylan is offline
