bed bolts - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 19 (permalink) Old 07-19-2010, 11:54 PM Thread Starter
Smell My Finger
juniort444e's Avatar
Send a message via AIM to juniort444e
bed bolts
wasnt sure if this thread is in the right spot. but im taking the bed off my truck to get rid of rust and sure enough the bed bolts are not coming off and i tried everything, so they are going under the torch wed. i called a local ford dealer and they want $10 for each bolt and $4 for each nut/clip. does anyone know where i can get these bolts at for alot cheaper.
2001 F250 ECSB with stuff that works with other stuff and kills jasper transmissions
"Say HELLO TO MY LITTLE FWEIND
juniort444e is offline
post #2 of 19 (permalink) Old 07-19-2010, 11:57 PM
Re: bed bolts
I may get crap for this but as long as you get some grade 8 bolts and nuts and you will be good to go.
02 f250
countryboyrob is offline
post #3 of 19 (permalink) Old 07-20-2010, 12:19 AM Thread Starter
Smell My Finger
Re: bed bolts
i was thinking something alont the lines of that, wasnt quite sure where i would find some at that have a flatter style head on them
post #4 of 19 (permalink) Old 07-20-2010, 12:26 AM
Re: bed bolts
tractor supply should have them. I have a store by me called mid-state bolt and screw, its a michigan company and they carry any and every kind of bolt.
02 f250
post #5 of 19 (permalink) Old 07-20-2010, 12:45 AM
Super Hauler!
Super_Hauler's Avatar
Re: bed bolts
I got mine from Fastenall, they are damn near the same thing. They have a torx head/panhead i just put a big flat washer-nut on the bottom
Super_Hauler is offline
post #6 of 19 (permalink) Old 07-20-2010, 01:10 AM Thread Starter
Smell My Finger
Re: bed bolts
thanks ill have to see if and where there might be one here in pa
post #7 of 19 (permalink) Old 07-20-2010, 04:42 AM
All done now
Arisley's Avatar
Re: bed bolts
Overnight soak in PB. From underneath not on top. In the morning, heat them up with a torch and hit the with a BFH. The take them off.
Arisley is offline
post #8 of 19 (permalink) Old 07-20-2010, 04:49 AM
Science rulz
Coltaine's Avatar
Send a message via AIM to Coltaine
Re: bed bolts
One of them truckless bastards.
Coltaine is offline
post #9 of 19 (permalink) Old 07-20-2010, 04:51 AM
Busy Busy
Marty's Avatar
Re: bed bolts
Weld nuts to the top to remove.
443.553.9234 - 410.392.3262
Elkton, Maryland
2005 F450 - Tow Bitch
Marty is offline
post #10 of 19 (permalink) Old 07-20-2010, 05:09 AM
powerstrokin87's Avatar
Re: bed bolts
I tried welding nuts to top of mine and then the nut/clip underneath just broke. Plasma cutter time...
powerstrokin87 is offline
