under dash gauge pod question - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 07-16-2010, 02:58 AM Thread Starter
peterbilt'in
Rob02F350's Avatar
hey guys
anyone ever mount one of those under dash gauge pods on the fuse panel cover under the steering column?
thoughts? ideas? pictures?
thanks
-Rob
2002 F350 extended cab XLT, 4x4 auto,194K mi @ 10/25/13, ELF7405, DP F5, ultra light gauges, all kinds of "improvements" Yukon Grizzly locker 6K helper springs, x code fronts. 2 Y2K jetta Tdi. RC2 tuned
Rob02F350 is offline
post #2 of 10 (permalink) Old 07-16-2010, 03:38 AM
Waitin' on 500
Choupique108's Avatar
Re: under dash gauge pod question
rockinJW has one in his race truck.
1997
Single Cab Dually
S366 w/Irate mount and plenums, EFuel, Intercooler, P.I.S 175/80s,
Corbeau seats w 08 console, 19.5s, Black Interior with swede headliner and visors,
Custom badges, Flight Fab/DIY traction bars.
2012 CCSB F250 Ultimate Lariat.
Choupique108 is offline
post #3 of 10 (permalink) Old 07-16-2010, 04:22 AM
<<< THE GAUGE WHORE...
CSIPSD's Avatar
I assume you mean this one, but mod it to mount to the removable dash panel?
Joe
CSIPSD is offline
post #4 of 10 (permalink) Old 07-16-2010, 05:38 AM
01platinum's Avatar
Knew Joe would post on this. Joe the switches look awesome. I have my rocker switches for my compressor and horns there.
Real Diesels Have Stacks
New Tunes by Matt @ Gear Head - Auto Meter Gauges from Nate @ PTP
Air Dog II Fuel Pump
First RR Fuel System built by hand @ Murff Racing
More to come soon..........
01platinum is offline
post #5 of 10 (permalink) Old 07-16-2010, 10:15 AM Thread Starter
peterbilt'in
Rob02F350's Avatar
yes, in your opinion, is there enough room to mount that pod on the removable dash panel under the steering column?
post #6 of 10 (permalink) Old 07-16-2010, 02:30 PM
Lost Cause
Betaracer's Avatar
There might be room to mount it, but would it be practical there? Could you even see it? Would it interfere with entry, exit, and driving?
You can do anything to your own truck regardless if it makes any sense.
2016 F-350, FX4, CCLB, 6.7PSD, 7" OUO/ICON/FOX lift, 38x13.50-18 Toyo MT
Betaracer is offline
post #7 of 10 (permalink) Old 07-16-2010, 03:22 PM
CSIPSD's Avatar
There is no were you could mount it and still be able to see it... There is still the overhead pod, the dash top pod and the dash wrap...
Joe
CSIPSD is offline
post #8 of 10 (permalink) Old 07-16-2010, 09:41 PM Thread Starter
peterbilt'in
Rob02F350's Avatar
yeah, i like your 4 gauges on the instrument panel, i dont think i have enough room in my A pillar to run more wires up to a overhead pod.... autometer not so expensive gauges. ha ha.
personally i can look down under the steering wheel and see the panel how i have my seat set back and leaned. but i would be worried about hitting it.
guess ill have to look into the instrument cluster... and get creative to make some ultralite's and a phantom or 2 fit.
post #9 of 10 (permalink) Old 07-17-2010, 01:16 AM
Stroker67's Avatar
Any pics of this? Im running into the same issue, im wanting to buy three more gauges and do a quad POD on the A pillar and maybe a dual overhead POD, but am open to suggestions on where else to put them. I cant put them where your three are in the pic because i have a bin that opens up there that i use. Thanks.
Stroker67 is offline
post #10 of 10 (permalink) Old 07-18-2010, 04:17 AM
tbolt's Avatar
Couldn't you plumb the wiring up the pass side pillar? I sure wouldn't want to take my eyes off the road long enough to look down there on a windy mtn road. I would want them up at the windshield level myself
Glen
early99 f350 cc, lb, 2wd, drw, A pillar autometer guages, CTS monitor, AIS intake, 4" turbo back cat delete diamondeye exhaust, dptuner, pmt1, jw vb, Swamps ab inj, Adrenaline oil, Coolingmist, 180*T, Trucool cooler, spin on trans filter, Firestone air bags, 2" frt leveling kit, now chased by a 34' toyhauler
tbolt is offline
