New Tires. Now my steering feels loose. - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 17 (permalink) Old 07-09-2010, 07:52 AM Thread Starter
edge186's Avatar
I got new tires a few weeks back. they are Hankook Dyna-Pro ATm. they are the same size i had before, 285/75-16 . Ever since i got them the steering feels really loose. before these i had BFG's and it didn't have a problem but now the thing is all over the road. What could cause this?
2001 F-250 PSD 4x4 Lariat CC SB Auto
Power Hungry Performance
Edge CTS Insight
ATS 4" Straight Pipe
ATS Ported Compressor Housing
AFE Stage II Intake
DI Stainless Up-Pipes
BTS Valve Body
6.0 Billet Converter
6.0 32 Row Trans Cooler
Foil Delete
AIH Delete
CCV Mod
Firestone Ride-Rite airbags
edge186 is offline
post #2 of 17 (permalink) Old 07-09-2010, 07:55 AM
Kip
Kip's Avatar
Re: New Tires. Now my steering feels loose.
Tucker your tires suck thats what is causing the problem
2005 Chevy Duramax (thats right I have a chevy and am on PSN. I use to have a PSD and I like this place.
THE SAINTS still suck GO COWBOYS!!!!
Kip is offline
post #3 of 17 (permalink) Old 07-09-2010, 07:57 AM Thread Starter
edge186's Avatar
damn it kip who said you could use the computer? get back to work!
Edge CTS Insight
AFE Stage II Intake
BTS Valve Body
Foil Delete
AIH Delete
CCV Mod
edge186 is offline
post #4 of 17 (permalink) Old 07-09-2010, 08:00 AM
Kip
Kip's Avatar
I am working and doing my computer work for the day
Kip is offline
post #5 of 17 (permalink) Old 07-09-2010, 10:29 AM
ChaseN's Avatar
it's the teflon coat on the new tires.
just burn em down a bit and you're good to go!
i love that feeling
2013 F250 Platinum C/C 4x4 SWB
2013 F150 Platinum C/C 4x4 SWB
ChaseN is offline
post #6 of 17 (permalink) Old 07-09-2010, 11:43 AM
NEVRNF's Avatar
I am having the same issue. I just took off a set of ATM's and went with a Goodyear Dura Trac.
Tony
02 Excursion CR conversion with a few go fast parts
The truck
should have built
FOR SALE
NEVRNF is offline
post #7 of 17 (permalink) Old 07-09-2010, 12:20 PM
Arctic Fox's Avatar
I think the BFG AT's have an extra ply in the side wall, that will give them a stiffer feeling.
But I have always gotten that squirrely feeling with brand new tires.
With the old worn out tires the tread is all worn down so you don't get any side to side movement (from the tread), with new tires you have about 1/2" deep tread which has some give to it.... the tread will stick to the road but the 1/2" thick tread will sort of squish around between the road and the steel belts in the tire carcass.
2006 F-450 XLT 4x4 6.0 Auto 4.30L
Kelderman 4-Link Airbags, Lariat Seats, 2011 Mirrors
CTS, SCT, ARP's & oem Gaskets, BPD 6ph FICM
Spearco IC, Ported Intake, Powermax, 4" Exhaust
BPD Oil Cooler, Oil By-Pass Filter
46,000 miles
Arctic Fox is offline
post #8 of 17 (permalink) Old 07-10-2010, 03:55 AM Thread Starter
edge186's Avatar
you think if i get a better steering stabilizer it will help the problem? maybe a dual stabilizer? right now its just the stock one but i did just put another new stock shock on it.
Edge CTS Insight
AFE Stage II Intake
BTS Valve Body
Foil Delete
AIH Delete
CCV Mod
edge186 is offline
post #9 of 17 (permalink) Old 07-10-2010, 03:56 AM Thread Starter
edge186's Avatar
how did you like the ATM's? i wanted Nitto terra grapplers but the people at discount talked me out of them. they said these last longer especially if you pull a trailer at all. not sure if its true but i decided to try them anyways.
Edge CTS Insight
AFE Stage II Intake
BTS Valve Body
Foil Delete
AIH Delete
CCV Mod
edge186 is offline
post #10 of 17 (permalink) Old 07-10-2010, 04:03 AM
you want some of this?
smorris's Avatar
Mine was the same way with the pro comps. I could lay in it at 70 mph and it would get all squirrely and you could actually see the blackmarks on the road.
The rubber was really soft and the tread deep when they were brand new.
After some wear they stopped. It was kinda cool stepping it sideways at 70 mph though.
It left rubber powder all over the side of the truck till they wore down to 3/4 tread. Nothin wrong with your truck, just soft tires and deep tread. It'll get better with time.
2000 f-350 cc lb dually 4x4, BTS transmission
[email protected] 90 mph on MT mud tires and 8,000 #
coming soon--97 cc lb 4x4
smorris is offline
