Swaping out the dash - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 11 (permalink) Old 06-29-2010, 04:15 AM Thread Starter
Powerstroke Tinkerer
Big A's Avatar
I have a question for you guys.....I want to swap the dash out of my 2003 superduty diesel (7.3L) into the 2000 superduty diesel (7.3L) I just bought. Has anyone done this? Is it just a bolt in, or do I have to swap the harness too? How big of a job is it? Thanks in advance......
Big A is offline
post #2 of 11 (permalink) Old 06-29-2010, 08:19 PM
Waitin' on 500
Choupique108's Avatar
Re: Swaping out the dash
it will bolt right in. everything is the same.
1997
Single Cab Dually
S366 w/Irate mount and plenums, EFuel, Intercooler, P.I.S 175/80s,
Corbeau seats w 08 console, 19.5s, Black Interior with swede headliner and visors,
Custom badges, Flight Fab/DIY traction bars.
2012 CCSB F250 Ultimate Lariat.
Choupique108 is offline
post #3 of 11 (permalink) Old 06-30-2010, 05:19 AM Thread Starter
Big A's Avatar
What about the gauge cluster? I want to use the one out of the 2003. Can I use the wiring harness out of the 2000?
Big A is offline
post #4 of 11 (permalink) Old 06-30-2010, 04:02 PM
Waitin' on 500
i dont think the gauge clusters will swap since they are different.
1997
Single Cab Dually
post #5 of 11 (permalink) Old 07-01-2010, 03:13 AM Thread Starter
Big A's Avatar
Guess I'll have to swap out the wiring harness then.....
Big A is offline
post #6 of 11 (permalink) Old 07-01-2010, 03:25 AM
Waitin' on 500
it may work. i just dont know. i do know that you CANNOT switch from a 7.3 cluster to a 6.0 one. A few guys on here have done a 05+ dash swap and they still have their orginal cluster in there.
1997
Single Cab Dually
post #7 of 11 (permalink) Old 07-01-2010, 03:37 AM Thread Starter
Big A's Avatar
I'm not going to a 6.0L cluster......My 2003 that I rolled was a 7.3L, not a 6.0L. I'm stripping all the interior out of the 2003 to put in the 2000, because the 2003 was a black sport model.
Big A is offline
post #8 of 11 (permalink) Old 07-01-2010, 04:26 AM
Waitin' on 500
i know that but its the same principle.
the early 7.3s used roller odometers where as the later used digital and the gauge layout is much different.
1997
Single Cab Dually
post #9 of 11 (permalink) Old 07-01-2010, 06:07 PM
Layson's Avatar
If you took the wiring harness out and swapped them you would be ok.
The 2000 has a fuse panel under the dash and under the hood. Your 2003 has both fuse panels in the dash.
Layson is offline
post #10 of 11 (permalink) Old 07-01-2010, 06:26 PM
RDRCM
CooterBrown's Avatar
You'll need to swap the PCM too.
CooterBrown is offline
